M/C 2100-2150 JET Suggestions - JeepForum.com
post #1 of 3 Old 05-22-2010, 08:41 AM Thread Starter
frank c
1981 CJ5
I have my 81CJ5 258, I'm going to pick up the block at the machine shop today and I have a 2100 and a 2150 M/C carb to restore for it I am at 3200 ft elevation and will be using the jeep at 2500- 4500 ft elevations aproximately.
I'm going to do the distributor upgrade with the adapter , larger cap e-coil and probably summit cdi box Engine rebuild is stock specks except for .060 overbore.
The 2150 carb has # 50 jets in it I got it off a small v-8 ford p/up I don't know what size is in the 2100 havent taken apart yet.
Their both 1.08 Venturis
WHAT SIZE WOULD YOU GUYS RECOMMEND I HAVE IN THE carbs when I decide to install either one on the new rebuilt engine ?????????
From searching posts I've seen everything from 45's on up jet size ???
frank c is offline
post #2 of 3 Old 05-22-2010, 07:02 PM
RR4W
I use 46's at sea level. Reading other posts have suggested 47's at higher elevations.
RR4W is offline
post #3 of 3 Old 05-22-2010, 08:02 PM Thread Starter
frank c
1981 CJ5
Thats making me wonder if I can get away with using the 50's that are in it at my el. I'll even be at 5000 + ft at times.
What I;'m worried about is initial start up of rebuilt engine with the carb cause I dont want to put the original carter back on it.
frank c is offline
still not starting & choosing 2100 or 2150 CJfreak Jeep CJ Forum 3 07-03-2009 08:46 AM
304 w/ 2150 LSUtiger Jeep CJ Forum 4 02-18-2007 06:38 PM
Motorcraft 2100/2150 Conversion ?'s for 232/258 Orange Juice Jeep CJ Forum 3 04-18-2005 02:53 PM
What air cleaner assembly to use with MC 2100/2150? crzyglue Jeep CJ Forum 5 04-24-2003 11:17 AM
ideas? suggestions? mc 2100 swappers need help! KG4PAM Jeep CJ Forum 2 05-10-2002 10:42 PM
