Ls1 vss help - JeepForum.com
post #1 of 3 Old 02-16-2012, 10:00 AM Thread Starter
jhughes2013
1977 CJ7
Ls1 vss help
Anyone on here have an LS1 with a manual trans? What did you use for the VSS?
jhughes2013 is offline
post #2 of 3 Old 02-16-2012, 04:55 PM
Exposed
Exposed's Avatar
1981 CJ5
I am running Ford but I think VSS senders are alike. I bought one from Dakota Digital below. Most factory VSS speedometers are 8 pulses I think. Might need to verify. If you are running a D300, I have a good used one I will sell you cheap. It goes inline in front of your speedometer cable. It worked fine with my Autometer Speedometer. When installed the AX15, the VSS now is internal in the D300 from Novak.. PM me if interested or can help..
thanks
http://www.dakotadigital.com/index.c...rod/prd109.htm
Calvin
81 CJ5, Ford 331 EFI, AX15, D-300, Dana 44 (Detroit Locker)....
When there are more people voting for a living than working for a living,
We are DONE as a Country!!!!!!
Newly Acquired 2014 Grand Cherokee Summit
Exposed is offline
post #3 of 3 Old 02-16-2012, 06:07 PM Thread Starter
jhughes2013
1977 CJ7
Pm sent
'77 CJ7, LS1, NV4500/D300, Ford 8.8, 4" of lift, 33x12.50 BFG ATs...
