LS1 Engine. Need Transmission Choices: T5 vs T18 vs ? - JeepForum.com
post #1 of 25 Old 06-07-2011, 02:57 PM Thread Starter
tlannom
I have an 86 CJ7 with a Corvette LS1. I broke the main shaft in the current T5 transmission. GForce transmission says it shouldn't happen and to send the transmission to them for repair. Based on a little research it doesn't seem the T5 will last long behind the LS1. I have access to a T-18 but it's going to require new bell housing and a new output shaft for the Dana 300.
Option 1- repair T5 (approx $600)
Option 2- Spend more $ on the T18 (approx $1400)
Option 3- something else
I really don't use this Jeep to wheel all that much, but I am prone to put my foot in it around town.
Thanks for the help.
'86 CJ7 Laredo, LS1 Corvette engine, AX15 transmission, Dana 300 4:1 twin-sticked, RE 4 1/2" lift, YJ cage, Bzerk front/ rear bumpers
tlannom is offline
post #2 of 25 Old 06-07-2011, 03:07 PM
kickingprop
If you are married to keeping a manual tranny then I'd look for an SM465 or SM420. It should have the same bellhousing bolt pattern and then would only need to be adapted to the D300. SM465's are as strong at T18's and mostly easier to find. Granny gear is nice for wheeling too.
http://www.novak-adapt.com/knowledge/sm465.htm for a little knowledge
But I wouldnt waste time rebuilding a T5. I grenaded mine behind the 258 and opted not to keep it when I upgraded to the 5.3L LM7
I've been pretty happy with the 4L60E behind my 5.3 but long for the day I can get that third pedal back...
1985 CJ7 Project
Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed
Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete
Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning
Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday...
Chrome won't get you home...BUT Rattle Can Black may just get you back"
kickingprop is offline
post #3 of 25 Old 06-07-2011, 03:14 PM
CSP
If you don't wheel much you probably don't want a transmission with a granny low first gear (like the T18 or SM465). The T5 shouldn't even be considered, especially behind any V8.
CSP is offline
post #4 of 25 Old 06-07-2011, 04:06 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Looking back at all the problems you've had with the GForce, I'd junk it.
Do it once and put an NV4500 in.
I know it's not cheap, But it'll be cheaper up front than in the long run.
You get the best of both worlds with a 5.61/6.34 low first and a .73 overdrive.
You would be hard pressed to break it.
LT1CJ7 is offline
post #5 of 25 Old 06-07-2011, 07:46 PM
4lowherewego
1979 CJ7
x2 on nv4500. If going to keep manual... id go to nv4500 and be done with it and have all 3 pedals, granny gear, and overdrive, and unbreakable.
But, TH400, 4l60e could make potential auto choices.
DO NOT REBUILD T5....
79CJ7 360 .030 over, mc2100, T150, Dana20, Trak-Lock'd AMC20, 4" Skyjacker springs, 33" Boggers on aluminum American Racing rims.
4lowherewego is offline
post #6 of 25 Old 06-07-2011, 08:50 PM
lucdog
lucdog's Avatar
1980 CJ5
Is this the same T-5, that came stock in CJ's, or the one in think they used in Mustangs?
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #7 of 25 Old 06-07-2011, 09:07 PM
markso125
1982 CJ7
Bill
I would say its the stock NWC T5 because its got a Dana 300 transfer case bolted too it. They never made a World Class T5 that bolted up to the D300. Well there is a company doing a conversion now but its still not worth it to have one of those behind a V8 with a 100+ LBS transfer case hanging on the back end...
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
markso125 is offline
post #8 of 25 Old 06-08-2011, 07:06 AM
kickingprop
The NV4500 may be a big strong tranny, but it has its own flaws and requires quite a bit more work to make it fit. Do you have a body lift? If not you are looking at doing some serious tranny tunnel trimming to make it fit. This is not a small transmission.
with the right gearing, OD isnt necessary and the 1:1 final of the SM465 or T18 gives good highway cruising RPMs and the deep granny still allows for crawling. NV4500's cost a LOT more as well...
1985 CJ7 Project
post #9 of 25 Old 06-08-2011, 10:06 AM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Any upgrade we do costs time, money and something always needs to be modified.
Why do you think they are called mods ???
The 1:1 final 4 speed is only going to get you so far with the correct gear,
And is not able to be finer tuned like a 5 spd.
Low range speed, highway speed and you forgot fuel mileage.
No good trans swap is cheap to do.
If the op want's to stay 5 speed..... Go with the NV4500.
LT1CJ7 is offline
post #10 of 25 Old 06-08-2011, 10:22 AM
garretj64
1982 CJ5
I found my NV4500 for $500 last November, also its not too bad to make it fit either. It really is the best manual tranny for a powerful V8
1982 CJ5, Corvette 383... project
garretj64 is offline
post #11 of 25 Old 06-08-2011, 10:32 AM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
LT1CJ7 is offline
post #12 of 25 Old 06-08-2011, 07:39 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
I tend to agree with this statement. Running 3.73's with 33's puts you in the ball park for a straight four speed. It also allows for larger tires in the future and eliminates the need to regear to 4.88's as the op is looking to do. The SM is a short trans and the adapter is small as well. The overall short length will help keep that rear driveline as long as possible, an issue with the 4.5" lift. It is almost a bolt in exchange using all GM drivetrain parts.
jeepdaddy2000 is offline
post #13 of 25 Old 06-08-2011, 08:03 PM Thread Starter
tlannom
Thanks to everyone for all the input. Based on the comments so far, here are my comments/ concerns:
  • T5- Gone.
  • T18- Turns out my friend didn't have a T18. Not really leaning in this direction.
  • NV4500- Love the durability. Not all that concerned about the price but REALLY concerned about the fit and modifying the transmission tunnel.
  • automatic choices- maybe cheaper and durable but really enjoy the third pedal. Not really leaning toward going to automatic.
  • SM465- leaning in this direction for a couple of reasons. Fit and gearing. Looks like I won't have to regear the Dana 300 or the axles if I go with this choice.
I think I may let a local 4X4 shop put everything back together. Depending on what they say and the expense, I may go with the NV4500. If it's too expensive and I have to do it my self, then it sounds like the SM465 may be a better option. I really appreciate all the comments. Keep 'em coming. I will keep you guys posted.
Thanks
tlannom is offline
post #14 of 25 Old 06-08-2011, 11:00 PM
JeepnBlake
You may consider the sm420 as well, the older similar version of the sm465. Both of which will likely require adapters to adapt to your transfer case.
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #15 of 25 Old 06-09-2011, 06:54 AM
kickingprop
1985 CJ7 Project
engine/transmission choices. silvzj95 Jeep CJ Forum 0 11-09-2010 10:56 AM
CJ7 transmission going out. What are my choices? mikeallegro Jeep CJ Forum 5 10-25-2010 01:58 PM
Newbie wanting help on engine and transmission choices for a cj7! bryce1974 Jeep CJ Forum 29 01-20-2010 08:59 AM
Engine and Transmission Choices Cpolinsky Jeep CJ Forum 1 03-12-2009 03:39 AM
72 cj5 transmission choices Sacgun1 Jeep CJ Forum 3 03-05-2007 03:57 PM
