lowering t-case - JeepForum.com
post #1 of 2 Old 03-29-2004, 03:52 PM Thread Starter
cjryder
lowering t-case
I have a 75 cj5 with a 4 inch spring lift.
I was thinking I should lower the d20 t-case about an inch or so.
Will this effect the linkage? What else?
75 cj5 , 51 m38
"the wife asks 'why 2 jeeps?', I tell her that's all I could find so far"
cjryder is offline
post #2 of 2 Old 03-30-2004, 07:00 AM
jadams68
jadams68's Avatar
Are you lowering it because you are experiencing driveline vibrations?
If so, dropping it 1" won't affect the linkage.
If you have a 1" or more body lift and you drop the t-case 1", you may have to cut a little bit around the shifter holes in the tub so you can get it into gear. Not a problem if you have a straight shifter.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
Lowering transfer case Jeep Rider Jeep CJ Forum 5 04-07-2010 09:12 AM
T-Case lowering kit MoC Jeep CJ Forum 17 11-06-2009 12:04 PM
T-case Lowering Kit BAH07 Jeep CJ Forum 1 08-06-2008 11:38 PM
transfer case lowering kit weatherford Jeep CJ Forum 1 11-20-2006 08:39 PM
Transfer Case Lowering csymonds Jeep CJ Forum 8 10-25-2004 08:19 PM
