Quantcast Lower Rear shock mounts - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Lower Rear shock mounts
Old 01-21-2009, 05:24 PM   #1
Jeeper83
1983 CJ7
Last time i had my CJ7 out i bent both rear lower shock mounts. Does anyone have ideas where to relocate them at or if they are replaceable? I know if i out them back at the same place or bend the ones back that are bent now they will probly break off! Thanks for the help!
Jeeper83 is offline   Reply With Quote
Old 01-21-2009, 05:52 PM   #2
dirtman13
2007 CJ7
I moved mine to the axle tube and install Ford shock towers up through the floor board. I made custom covers and used them to mount the rear seat using quick disconnects. It was quite the project.
dirtman13 is offline   Reply With Quote
Old 01-21-2009, 06:30 PM   #3
Mike Romain
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
You 'really' need to get shocks that fit your springs. Too short or too long will always break something, I have seen shocks punched through the back seat even.
The other thing that stops breakage is the proper sized bump stops or if you bent on the droop limiting straps.
Mike
86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Old 01-21-2009, 06:35 PM   #4
sabu
1983 CJ7
Shock Mounts
Got a pair from Quadratec recently. Replace the U-bolts at the same time.
sabu is offline   Reply With Quote
Glock Forum
