low voltage... - JeepForum.com
post #1 of 5 Old 09-27-2006, 07:13 PM Thread Starter
jy4wvu
low voltage...
I have an 84 CJ7. I have replaced the alternator. I have replaced battery cables and a new battery. I have replaced the starter solenoid. When i use the headlights and/or heater, the voltage drops below 12 volts. If i drive for 30 minutes that way, the battery dies. Any help????
is there a voltage regulator external of the alternator??
jy4wvu is offline
post #2 of 5 Old 09-27-2006, 07:29 PM
Bard
Either way if you have a 4 or 6 cyl, you could have gotten a bad alternator, which could work for a short period of time. I have had this happen before. Take it off and have the parts store test it where you bought it. If it comes back negative, you have a bad ground somewhere which is drawing off the battery, but I think it is the alternator by the sounds of your problem.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #3 of 5 Old 09-28-2006, 01:05 PM Thread Starter
jy4wvu
i took alternator in for test....it is ok. i have re-ground everything. I have 2 wires on the alternator plug in...red and white. does the white go to ground??
jy4wvu is offline
post #4 of 5 Old 09-28-2006, 06:24 PM
gosupes
You might try upgrading to a larger gauge wire from the alt to the solenoid post also. I was losing about 4 volts with everything running and the stock 10awg wire. I installed a 2awg wire from a chunk of battery cable with some heavy copper terminals soldered on. No more loss.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
post #5 of 5 Old 09-29-2006, 03:54 AM
John Strenk
John Strenk's Avatar
1976 CJ5
You mean it's not hooked to anything now and you got it working!?? Shazaam!!
Case of the alternator is ground the red heavy gauge wire comming out of the 2 wire plug goes to the output post. the other wire, normally brown or tan, conects back to the ignition switch. This is usually a thin fragle resistance wire that is usually pooly crimped into the terminal.
John Strenk is offline
different voltage golferwt Jeep CJ Forum 6 06-14-2009 05:21 AM
Voltage Question fireslider Jeep CJ Forum 5 08-28-2008 10:00 PM
alternator voltage kappa505 Jeep CJ Forum 23 12-07-2006 09:02 PM
voltage MudMonster Jeep CJ Forum 30 04-05-2004 01:27 PM
Voltage Reg?? cj5mudman4x4 Jeep CJ Forum 3 02-21-2003 04:10 PM
