Low Compression - help!!! How to do the test??? - JeepForum.com
post #1 of 8 Old 04-16-2012, 06:36 AM Thread Starter
warrior1670
Ok, so I got my new carb on, the motor runs great. 258 with new motorcraft 2150 no emissions crap. It was missing on #4, replaced the plugs last night, miss gone.
So, before that, the guy working on it said it had very low compression on #1 and #2, he didn't check the rest. It fires up great, runs, little sluggish, blew very little smoke. I'm not sure if this is from #4 missing or not. He did the compression test cold.
So, I did a cold compression test, between 58 and 61 psi on all cylinders. I know this is very low but should this thing be running with it that low? What's the correct procedure for a compression test? I pulled a plug, put the compression gauge in it, started it, cleared the gauge, it went to 60 in three pulses and sat there. If it opened the throttle, it went up dramatically over 100 but didn't think this was right.
So, what's the correct way to do it?
Secondly, is there a way to tell if it's the rings or valves? Since all cylinders are dramatically low, could it be something else?
warrior1670 is offline
post #2 of 8 Old 04-16-2012, 07:01 AM
hotrod351
1955 M-38
ive never held the throttle open and have never, and i mean never, had any problem in getting a good reading. if you have a air compressor you can connect the hose to the compression tester and shoot air into the cylinder. if you hear air coming out of the valve cover where you put oil then its valves, if you hear it coming out the exhaust pipe then rings.
hotrod351 is offline
post #3 of 8 Old 04-16-2012, 07:11 AM
h2ogun
Pull all your plugs
Wire your carburetor wide open
For each cylinder , Crank your engine until you get about 3 compressions
h2ogun is offline
post #4 of 8 Old 04-16-2012, 08:15 AM
Centerfire
The Manual
Compression Test Instructions
Page B-19
http://www.civilianjeep.info/84-86FSM/CJ-FSM-84to86.pdf
In addition;
There is also a "Wet" compression test. Squirt a couple teaspoons of oil into the cylinder and test the compression. If the compression came up on the wet test, your rings are probably bad. If it stayed the same its probably a valve.
Then use the compression leak down test to verify ...
Centerfire is offline
post #5 of 8 Old 04-16-2012, 07:29 PM Thread Starter
warrior1670
Thanks for the help everyone. Got good news and bad. Good news, I got the test done dry and wet. More good news, it's not 60psi/cylinder. Bad news, still 100-110 psi. Eh better than 60 I guess. Thanks. Starting a new thread for opinions.
post #6 of 8 Old 04-16-2012, 08:07 PM
Trapshooter
How many miles on the engine? How much oil is the engine consuming between changes? What kind of values where you hoping for?
Your results of 100-110 psi isn't bad for a high mileage engine. Consistency between cylinders is more important than high readings. This ensures the cylinders share an equal amount of work.
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #7 of 8 Old 04-16-2012, 09:36 PM
BagusJeep
1981 CJ7
The spec for a 258 is 120-150 psi with max 30psi variation between cylinders.
If you have an even 110psi, it is a little low but not catastrophic.
What did the dry and wet tests show? Is it valves or rings?
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #8 of 8 Old 04-17-2012, 06:01 AM Thread Starter
warrior1670
The dry check resulted in 100-110 across the board, did the wet check on #1 cylinder and it went to 150psi. Does that show if it's rings or valves? Everyone says the wet test shows it's rings. 130K on the engine.
How do you do a compression test? WNC-84CJ7 Jeep CJ Forum 4 09-24-2011 06:14 PM
Compression test trueprimitive Jeep CJ Forum 5 10-31-2009 11:09 AM
Compression Test Results - Help howelljeep Jeep CJ Forum 1 08-29-2007 03:10 PM
304 Compression Test CJ Runner Jeep CJ Forum 0 07-14-2007 04:37 PM
compression test?????? idaho elk Jeep CJ Forum 2 06-29-2007 06:27 AM
