Loud , violent, and shakey startup, runs smooth after - JeepForum.com
post #1 of 6 Old 05-10-2013, 09:46 AM Thread Starter
DrPepperBrown
Hey there, I am new to the CJ community, i just bought an 84 CJ7 from a friend of mine - its a 2.5L 4cyl - he towed (with a towbar) from Missouri to Nashville 8hr ride. He put the transmission into N position and headed my way. After I picked up the jeep, on the 5th or 6th startup it start making a loud noise every time i started the engine. As if something wasnt fully engaging, but after it started it runs like a dream. Could it be something to do with the transmission not being engaged all the way? or is it my flywheal gear?
I'm about to take off the starter and pray it's not the flywheel, but if it is the flywheel what kind of repair job am i looking at?
thanks for taking the time to help out a newbie!
- sam
DrPepperBrown is offline
post #2 of 6 Old 05-10-2013, 09:54 AM
M20Keeper
1982 CJ7
So did he leave the transfer case in 2 or 4WD? if so I think that can have an adverse affect on the transmission, but I am not a transmission guy when I towed mine from OK to NJ, I put the transfer case in N and no issues at all. But I think they recommend that you remove the drive shaft for towing.
M20Keeper is offline
post #3 of 6 Old 05-10-2013, 10:08 AM
Balvar24
1979 CJ7
Sounds kinda like a worn/mangled starter gear.
"Work hard, rock hard, eat hard, sleep hard, grow big, wear glasses if you need 'em."
Balvar24 is offline
post #4 of 6 Old 05-10-2013, 10:43 AM Thread Starter
DrPepperBrown
he put the transfer case in N. - sorry It sounds like a gear is grinding into place after 1 or 2 rotations.
post #5 of 6 Old 05-10-2013, 12:03 PM
Hawk4097
It could be a worn gear or alignment of starter to flywheel. It may ned a shim or your bolts may have even backed out. the sooner you get it fixed the less apt you are to making it a morre costly repair.
Hawk4097 is offline
post #6 of 6 Old 05-10-2013, 02:59 PM
LumpyGrits
Check the passenger side motor mount and tranny mount.
This are well known problem areas.
LG
LumpyGrits is offline
cj7
