-   -   Loud , violent, and shakey startup, runs smooth after (http://www.jeepforum.com/forum/f8/loud-violent-shakey-startup-runs-smooth-after-1521448/)
DrPepperBrown 05-10-2013 09:46 AM
Hey there, I am new to the CJ community, i just bought an 84 CJ7 from a friend of mine - its a 2.5L 4cyl - he towed (with a towbar) from Missouri to Nashville 8hr ride. He put the transmission into N position and headed my way. After I picked up the jeep, on the 5th or 6th startup it start making a loud noise every time i started the engine. As if something wasnt fully engaging, but after it started it runs like a dream. Could it be something to do with the transmission not being engaged all the way? or is it my flywheal gear?
I'm about to take off the starter and pray it's not the flywheel, but if it is the flywheel what kind of repair job am i looking at?
thanks for taking the time to help out a newbie!
- sam
M20Keeper 05-10-2013 09:54 AM
So did he leave the transfer case in 2 or 4WD? if so I think that can have an adverse affect on the transmission, but I am not a transmission guy when I towed mine from OK to NJ, I put the transfer case in N and no issues at all. But I think they recommend that you remove the drive shaft for towing.
Balvar24 05-10-2013 10:08 AM
Sounds kinda like a worn/mangled starter gear.
DrPepperBrown 05-10-2013 10:43 AM
he put the transfer case in N. - sorry It sounds like a gear is grinding into place after 1 or 2 rotations.
Hawk4097 05-10-2013 12:03 PM
It could be a worn gear or alignment of starter to flywheel. It may ned a shim or your bolts may have even backed out. the sooner you get it fixed the less apt you are to making it a morre costly repair.
LumpyGrits 05-10-2013 02:59 PM
Check the passenger side motor mount and tranny mount.
This are well known problem areas.
LG
The time now is 03:30 AM.
