Lots o' Questions - JeepForum.com
post #1 of 9 Old 04-26-2002, 10:48 PM Thread Starter
Nick03
Post Lots o' Questions
Ok fellas here's the deal
I bought a manual '86 CJ-7 about two and half months ago and now I'm ready to do something with it. Here's what I know I would like to do so far, but I need some more info on how, what, and where I should do it. I know I want to put some 33'' AT's on it and from what I've read, a 4'' suspension lift is the way to go. What about a body lift? 1''? For the suspension lift should I go with the Skyjacker? Everything is stock and I bought it with from the original owner and she only had about 59,000 miles on it so that can tell you how much it was driven. Also, it has some rust (now holes) in the backseat where the seatbelts used to bolt down as well as in the floorboards. How do I go about getting that taken care of? Should I get that taken care of before I do any lifting?
Nick03
'86 CJ-7
Nick03 is offline
post #2 of 9 Old 04-26-2002, 11:30 PM
nvyblue_cj7
Post
I'm kinda in the same predicament, choosing between necessity and pleasure, lol. One thing I've learned is to get everything on your jeep in working condition before you start modifying (walk before you run). So, I'd say to get some sheet metal and get to welding your floor back in, then fix up your seatbelt problem for your rear seat. You'll be happier in the long run.
Nick
1984 CJ7-31" BF Goodrich AT Tires, Auto, 258 ci, Pioneer sound, 2 barrel Weber carb, undergoing some body work and exhaust work sometime soon.
"pop the hood, POP THE HOOD!"
- a phrase commonly heard in my garage
nvyblue_cj7 is offline
post #3 of 9 Old 04-27-2002, 10:29 AM
4wheeler4CJ
4wheeler4CJ's Avatar
Arrow
First of all, I agree, I'd worry about fixing up your floor. Cut out all the bad spots and weld new steel in. SEAL THE EDGES with a quality "Seam-Sealer" (before painting) wherever you make a patch, it will save the repair for many years over not sealing it. You can get good seam-sealer at your local auto parts store. It's not cheap, but it's worth it.
As far as the seatbelts, the rear seatbelts are attached to the Frame of the Rear Seat, not directly to the floor. Do you mean the seat frame is rotted itself where the belts are attached? If so, if it is really bad, you may want to just get another seat in good shape, it's sometimes not worth trying to patch something like that.
You won't need a 1" body lift for 33s, a 4" suspension lift will do very nicely, and, yes, I would recommend the Skyjacker kit (check with Quadratec, they have a totally complete kit for around $600 roughly). I had great luck with a 2.5" Skyjacker kit for 8 years before passing it on in a partial trade a few months ago, when I parted my old Jeep out. The new "owner" of the kit loves it! You're gonna probably get some posts from others that it is junk, etc., and to buy all these other heavy duty kits. That may be fine if you off-road all the time, hard core, and rock crawl, but if you don't, you may find the other kits a bit of overkill and rough-riding. The Skyjacker gives a super-smooth ride, my 2.5" kit rode much better than stock. <img border="0" title="" alt="[Wink]" src="wink.gif" />
Good Luck with the "project"!
4wheeler4CJ is offline
post #4 of 9 Old 04-27-2002, 12:31 PM Thread Starter
Nick03
Post
Thanks for the advice. About the seatbelts: I meant to say that the drivers seatbelt isn't bolted down to the floor anymore- not that the backseat passenger's seatbelts were rotted. Although you havent's seen the Jeep, what do you think a rough estimate of the welding would be?
Nick03
'86 CJ-7
Nick03 is offline
post #5 of 9 Old 04-28-2002, 08:38 AM
4wheeler4CJ
Arrow
I couldn't even wager a guess, sorry. That kind of work is very variable as far as cost. Depends on the extent of rust, how many areas, what areas, etc. Also depends on the place you have it done.
I can say it won't be too cheap, welding shops get a decent coin usually. I have a MIG Welder & Torches and do my own repairs, so I can't tell you exactly. Your best bet is get some prices from some guys near you, or find a friend or someone who can do it "on the side". <img border="0" title="" alt="[Wink]" src="wink.gif" />
post #6 of 9 Old 04-28-2002, 08:47 AM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Post
I loved my 2.5" Skyjacker/Softride lift on my CJ!
As far as body rust goes -
Here are some pics of an extremely rusty CJ5 that we replaced the bed and wheelhouses on - all we really intended to do was upgrade his rollcage but figured what's the sense if there's nothing to bolt it to!
<img src="http://www.dehesa4x4.com/mckay/images/Robs%20Jeep/DCP02093.JPG" alt="" />
<img src="http://www.dehesa4x4.com/mckay/images/Robs%20Jeep/DCP02097.JPG" alt="" />
<img src="http://www.dehesa4x4.com/mckay/images/Robs%20Jeep/DCP02100.JPG" alt="" />
<img src="http://www.dehesa4x4.com/mckay/images/Robs%20Jeep/DCP02112.JPG" alt="" />
Steve
OldJeepguy is offline
post #7 of 9 Old 04-29-2002, 08:23 AM
4wheeler4CJ
Arrow
Gee,
Kinda looks like my '77 CJ-7 body that i am doing now! LOL <img border="0" title="" alt="[Wink]" src="wink.gif" />
Nice solid repairs, that what I like!
post #8 of 9 Old 04-29-2002, 12:05 PM
TG CJ7
Post
OldJeepguy,
That looks nice. How'd you keep the body panels from warping?
1979 CJ7 Renegade 304, 3spd, 2.5 BDS lift, Hedman headers.
Check it out
TG CJ7 is offline
post #9 of 9 Old 04-30-2002, 11:42 AM
4wheeler4CJ
Arrow
He didn't do any direct welding to the exterior skins, he welded to the fender wells and floor mostly, they wouldn't really cause deformation of the exterior skins.
Sorry, Oldjeepguy, for answering it, just catching it in case you miss it.
New CJ, Lots of Questions (transmission, wiring) SEALLogan Jeep CJ Forum 4 07-09-2009 08:34 AM
Newbie-Just bought a 76 CJ7 Have lots of questions and need advice!! tyler_stephen Jeep CJ Forum 4 09-10-2007 06:39 PM
Got the new Carb in, now Ive got questions (lots of pics) Fropleyqk Jeep CJ Forum 6 05-20-2005 01:18 PM
New CJ7, lots of questions Pete-o Jeep CJ Forum 2 09-14-2004 09:19 AM
lots of questions. stuntman Jeep CJ Forum 2 10-26-2003 03:45 PM
