Lost top end speed - JeepForum.com
post #1 of 84 Old 04-22-2013, 08:14 PM Thread Starter
firemanjim7
1983 CJ7
Lost top end speed
Just completed the CRT hei install and instantly noticed no more miss at idle and low end power smooth and increased. Problem is now it will barely hit 70. I increased the timing from 8 to 12 it helped alittle 72 but that's floored flat smooth highway. Before the change out I could cruise at 75 with pedal left. Any thoughts?
firemanjim7 is offline
post #2 of 84 Old 04-23-2013, 02:10 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I would check the advance curve of the distributor you just installed. Maybe it needs soe tweeking.
Did you change plugs at the same time? What type did you use?
John Strenk is offline
post #3 of 84 Old 04-23-2013, 04:28 AM
86cj74.2L
86cj74.2L's Avatar
Do you hear detonation.
86cj74.2L is offline
post #4 of 84 Old 04-23-2013, 04:50 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
What dizzy was in there before?
Matt
Matt1981CJ7 is offline
post #5 of 84 Old 04-23-2013, 07:12 AM Thread Starter
firemanjim7
1983 CJ7
Yes changed plugs. Champion copper
post #6 of 84 Old 04-23-2013, 07:14 AM Thread Starter
firemanjim7
1983 CJ7
Matt
Just a tad of detonation when I moved it to 12. The previous dizzy was stock.
post #7 of 84 Old 04-23-2013, 07:54 AM
Matt1981CJ7
1981 CJ7
I'm with John on this one. Check the total advance curve (centrifugal + initial) of the hei.
If you kept the wiring for the Duraspark, you could also re-install it, then compare the curves. If timing is the issue, the top-end of the curves will likely tell the story.
Matt
post #8 of 84 Old 04-23-2013, 08:09 AM
86cj74.2L
86cj74.2L's Avatar
If its a standard HEI curve and not altered for a 258 they have 20 total advance and it comes in quicker then it should
post #9 of 84 Old 04-23-2013, 09:08 AM
swatson454
1983 CJ7
What rpm is it knocking at? Can you be pretty descriptive of when it occurs?
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now
post #10 of 84 Old 04-23-2013, 09:36 AM Thread Starter
firemanjim7
1983 CJ7
Shawn
The knock is only under a hard load not any specific rpm. As for the curve set up I'm not sure it was ordered from CRT for the 258. I talked to mechanic and he seems to think I might need a vacuume delay valve thinking it is loosing vacuum too quickly at WOT and loosing advance.
post #11 of 84 Old 04-23-2013, 09:40 AM
82JeepCJ7
1982 CJ7
I had the same issue with my HEI. I adjusted the vacuum advance curve (allen wrench goes in where the vacuum line attaches on the advance). Until I adjusted the curve, I could get good idle and regular running, but when advancing hard, it would ping.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #12 of 84 Old 04-23-2013, 09:46 AM
swatson454
1983 CJ7
You really need to remove and plug the vacuum advance and accelerate hard up to redline. This should isolate your problem: either vacuum advance issue (if the knocking goes away) or the centrifugal curve/initial advance setting.
It's a crapshoot without knowing exactly where your problem lies. You might get lucky and make it quit knocking but you won't know if you just slapped a band aid on it; in which case, performance everywhere else could suffer.
Shawn
Edit: if you only got a touch of detonation when you went to 12*, I don't suspect you have a vacuum advance issue. It might be happy just backing off the initial advance 2*.
post #13 of 84 Old 04-23-2013, 09:50 AM Thread Starter
firemanjim7
1983 CJ7
Which way did you adjust in or out ? What did your initial timing end up being?
post #14 of 84 Old 04-23-2013, 09:52 AM Thread Starter
firemanjim7
1983 CJ7
You really need to remove and plug the vacuum advance and accelerate hard up to redline. This should isolate your problem: either vacuum advance issue or the centrifugal curve/initial advance setting.
Shawn
I'm pretty sure my knocking is coming from too much initial advance.
post #15 of 84 Old 04-23-2013, 09:56 AM
swatson454
1983 CJ7
Sorry dude, I snuck an edit in there
