Losing brakes when Jeep's turned on - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Losing brakes when Jeep's turned on
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 06-26-2011, 10:26 PM   #1
Mp5ben
I was checking the Master Cylinder to see if it had enough fluid today, it did, so I popped the cover back on and started the jeep and the pedal immediately went straight to the floor with no resistance. Every time I turned it off, the pedal would return to normal. I tried this about 4 times and with the same results each time. I bled the brakes about a month or two ago and they were fine.
Any idea what happened?
Mp5ben is offline   Reply With Quote Quick reply to this message
Unread 06-26-2011, 10:30 PM   #2
benullman
1981 CJ7
do you have a vacuum booster (im guessing yes)
you havent got all of the air out of the lines, or you need to adjust the linkage. But I would get a friend and re bleed them because it may have a small leak and air gotten in
Ben
[QUOTE=Gregg79CJ7304;11634021]Great minds think alike, but so do serial killers......Thanks.[/QUOTE]
benullman is offline   Reply With Quote Quick reply to this message
brakes , cj7
