Losing brakes when Jeep's turned on - JeepForum.com
post #1 of 2 Old 06-26-2011, 09:26 PM Thread Starter
Mp5ben
2005 WK
I was checking the Master Cylinder to see if it had enough fluid today, it did, so I popped the cover back on and started the jeep and the pedal immediately went straight to the floor with no resistance. Every time I turned it off, the pedal would return to normal. I tried this about 4 times and with the same results each time. I bled the brakes about a month or two ago and they were fine.
Any idea what happened?
Mp5ben is offline
post #2 of 2 Old 06-26-2011, 09:30 PM
benullman
1981 CJ7
do you have a vacuum booster (im guessing yes)
you havent got all of the air out of the lines, or you need to adjust the linkage. But I would get a friend and re bleed them because it may have a small leak and air gotten in
Ben
Originally Posted by Gregg79CJ7304 View Post
Great minds think alike, but so do serial killers......Thanks.
benullman is offline
brakes , cj7
Your Jeep's name? 1980tallcj7 Jeep CJ Forum 201 08-09-2014 09:58 PM
A step back to Jeep's worst day in history. IDK Jeep CJ Forum 21 11-05-2009 10:25 AM
Original tires 85 CJ-7. 29"??? Jeep's in the shop and I'm UGA6 Jeep CJ Forum 1 09-30-2008 08:36 AM
Will a new fiberglass tub increase my Jeep's value? Hillbillyd Jeep CJ Forum 8 03-11-2004 12:11 PM
Jeep's high and dry - clutch linkage ImNotRyan Jeep CJ Forum 4 01-26-2003 12:33 PM
