loosen power steering belt - JeepForum.com
post #1 of 8 Old 03-09-2010, 02:35 PM Thread Starter
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
how does one loosen the power steering belt on a 258? i am trying to replace it and just cant figure it out. i have the alternator belt free just cant get this one. thanks a lot!
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #2 of 8 Old 03-09-2010, 03:03 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
With a wrench or ratchet...........
There should be a through bolt that runs front to back
Another one on the front and another one on the back.
They can be hard to see, But they should be there.
Don't pry on the can/reservoir.
LT1CJ7 is offline
post #3 of 8 Old 03-09-2010, 06:27 PM
baldfatdad
1984 CJ8
Clean the area between the filler and the block with some mineral spirits. Mine gets filthy. The bolts are 15mm on my 84. Curse it every time I have to do it. Only metric on my jeep. There is a square hole in the back of the mount just up from the return line. Use a ratchet or breaker bar to move the pump. Its backward from what you'd think. Up to loosen.
baldfatdad is offline
post #4 of 8 Old 03-09-2010, 06:29 PM Thread Starter
RobsCrawlin7
no balls
thank you for the info, ill give another shot tomorrow
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
1 April 2007
post #5 of 8 Old 03-10-2010, 06:25 AM
Mike Romain
One 15 mm bolt under the top of the pulley, one in the same place behind the pump. These are the pivot bolts, then one long one down in the center of the plate toward the engine which is the adjuster/locking bolt you loosen. To tighten it, use a socket wrench in the square hole on the back as mentioned, then tighten the long locking bolt first, then the two pivot bolts but don't go too tight on the belt.
Mike
Mike Romain is offline
post #6 of 8 Old 02-05-2012, 08:56 AM
CJcool
As always, this forum solves problems and saves money. I spent the morning replacing my water pump and ran in to the same issue with loosening the power steering belt. It was not obvious but with an iPad and the jeepforum.com the problem is solved. I attached a photo to help others 'see' where the two bolts are that must be loosened to pivot the pump. A socket is on both of them for your reference. Both are 9/16. Hope this helps someone.
CJcool is offline
post #7 of 8 Old 02-05-2012, 09:02 AM Thread Starter
RobsCrawlin7
no balls
thanks...long since resolved but this might help someone in the future
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
1 April 2007
post #8 of 8 Old 02-05-2012, 09:54 AM
GlennLever
GlennLever's Avatar
Ok, the bolts have been identified.
The best way to move the pump once the bolts are loose is to insert a breaker bar into the square hole on the back side of the braket holding the pump and use it to move the bracket.
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
New steering box and power steering pump=very tight steering? SuB8HaVeN Jeep CJ Forum 15 04-12-2010 11:13 AM
Will the hoses on a 82 power steering pump mate up with a 89 power steering box? Mud Machine Jeep CJ Forum 2 12-17-2005 09:18 AM
Power steering belt coloradocj-7 Jeep CJ Forum 3 06-16-2005 09:13 AM
what bolts to loosen to tighten power steering belt? rwcloukey Jeep CJ Forum 3 09-01-2003 09:02 PM
mopar mpi, power steering brackets, serpentine belt DaJeeper Jeep CJ Forum 0 08-25-2003 10:47 AM
