Loose Steering? - JeepForum.com
post #1 of 7 Old 07-08-2007, 05:16 PM Thread Starter
GittinAJeep
Loose Steering?
I went and test drove a CJ 5 today, all in all I really liked it, and more importantly my wife liked it.
One issue is that the steering seems to be really loose. There is a lot of play in the steering wheel, I only went about 45-50MPH and faster than that and it seemed like it would get scary. The current owner agreed and said that he liked to keep it at 55 at the most. Is this a common problem? Is it hard to fix?
GittinAJeep is offline
post #2 of 7 Old 07-08-2007, 05:53 PM
SuB8HaVeN
That is definitely a common problem for the CJs (and really all the older Jeeps). Every situation is different. You may have a slap worn out steering box, or it may be your tie rods or something else. I've just learned to keep both hands on the wheel and be very careful at speeds over 60...
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress)
1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress)
SuB8HaVeN is offline
post #3 of 7 Old 07-08-2007, 06:00 PM
bdmonist
WTF is that?
bdmonist's Avatar
It's a fairly easy fix in most cases. New box, tie rod, ends, steering shaft, etc.
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift.
In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles
Coming Soon - CV Shafts, Welded Tubes, trusses
bdmonist is offline
post #4 of 7 Old 07-08-2007, 06:43 PM
79cj7reny
1979 CJ7
Tie rod ends, ball joints, wheel bearings, spring bushings, steering box, cracks in frame where box mounts to. Any or all of these things will contribute to loose steering. All easy fixes though. Price out the possible repairs and knock that off your offer.
79cj7reny is offline
post #5 of 7 Old 07-08-2007, 06:57 PM
Later_THANKS
Later_THANKS's Avatar
Jack the front end off to the point where the wheels are off the ground
Then grab each wheel and shack and see what moves around.
Rob99 Fan Club Member#00
Beware users with very thin skin:
gschretter
Later_THANKS is offline
post #6 of 7 Old 07-08-2007, 07:25 PM
kavephish
1981 CJ5
I had exactly the same thing....an absolute death machine at 30mph+.....fixed 2 tie rod ends $40.00, all 4 ball joints $80.00, lower steering box brace $50.00,replaced steering box $260.00 (seals blown due to rusted ball joints), installed missing sway bar and new bushings $75.00, and tightened the loose steering box brace bolts inside the frame $aggrivation$. Steers perfectly now. Put a lot of hours into it too because of the rust, but overall the mechanical aptitude required to fix all the above is low. You may have fewer worn parts than I did, you may have more. PLUS I was able to convince my wife that I NEEDED a 20 ton press ($210.00) to do the ball joints..
kavephish is offline
post #7 of 7 Old 07-08-2007, 08:18 PM
Trapshooter
It may be as simple as adjusting the steering box, but most likely there is a mixture of worn out parts as kavephish stated.
You didn't mention how many miles on the rig.
You've got it made if the wife likes the rig.........Good Luck
Trapshooter is offline
why is my steering so loose kcfire64 Jeep CJ Forum 3 05-12-2009 11:48 PM
loose steering wheel....not loose steering meater Jeep CJ Forum 3 02-19-2008 02:06 AM
CJ Loose steering RH31379 Jeep CJ Forum 9 08-01-2007 06:27 PM
steering is loose 83 cj-7 258 Jeep CJ Forum 0 10-24-2004 02:20 PM
Loose Steering toothdoc Jeep CJ Forum 7 06-24-2004 11:03 AM
