Loose bulkhead connector wire - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Loose bulkhead connector wire
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!FLASH SALE! Open thread to reveil the Newest Sale @ ROCKRIIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 01-10-2015, 08:30 AM   #1
ericcuebas
1977 CJ7
I had no low beams so I replaced the lamps, hi/low switch and the connector with no success. Then I noticed the low beam wire was so loose that I was able to pull it out of the bulkhead connector with no effort. When I push it all the way in everything works fine.
I need help with how to firmly establish that connection at the bulkhead connector again. I've seen multiple threads re: no low beams but none that addressed this particular problem.
ericcuebas is offline   Reply With Quote Quick reply to this message
Unread 01-10-2015, 10:03 AM   #2
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I'd probably replace the connector.
IIRC it's a Packard 56 style connector.
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 01-10-2015, 11:09 AM   #3
John Strenk
John Strenk's Avatar
1976 CJ5
There should be a little tab on the terminal that holds it in place. If you bend it up a little, it may be enough to hold it in place.
However if it looks burnt, then the terminal may have over heated and melted the plastic housing. In that case you could move both terminal to another opening.
John Strenk is offline   Reply With Quote Quick reply to this message
Unread 01-10-2015, 11:37 AM   #4
ericcuebas
1977 CJ7
Not burnt at all. I'm gonna try and bend it up and jury rig it. If I do have to replace the connector; do I have to remove the bulkhead connector and/or fuse box? Thanks John Strenk and Matt.
Unread 01-10-2015, 04:00 PM   #5
John Strenk
1976 CJ5
You don't have to usually. The engine side unscrews pretty easily anyway.
Unread 01-10-2015, 04:06 PM   #6
slomo19er
1983 CJ7
Shove it back in the connector housing. Seal the rear off with JB Weld. Done..... No more issues and waterproof.
slomo
slomo19er is offline   Reply With Quote Quick reply to this message
Unread 01-10-2015, 04:09 PM   #7
John Strenk
1976 CJ5
slomo
And let the next owner worry about it, right?
Unread 01-10-2015, 04:14 PM   #8
slomo19er
1983 CJ7
Worry about what? JB Weld is non conductive. Will not let the wire go again like yours was. Just seal the back half and wires. Don't dunk it into a gallon jar obviously.
slomo
Unread 01-10-2015, 04:21 PM   #9
ericcuebas
1977 CJ7
Fixed, thanks all!
Unread 01-10-2015, 04:23 PM   #10
John Strenk
1976 CJ5
In case the terminal goes bad from any corrosive ingredients in JB Weld.
Unread 01-10-2015, 04:23 PM   #11
John Strenk
1976 CJ5
Originally Posted by ericcuebas View Post
Fixed, thanks all!
How?
Unread 01-11-2015, 12:45 PM   #12
ericcuebas
1977 CJ7
I ended up replacing the connector and sealing with dielectric grease. Thanks again guys
Unread 01-11-2015, 09:07 PM   #13
BagusJeep
BagusJeep's Avatar
1981 CJ7
So the 5 cent solution worked?
Go, John Strenk and Matt!!!
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1947 Willys CJ2A/3A/MB/M38 - Little Willy
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline   Reply With Quote Quick reply to this message
