Looks like negative camber on my D30, possibly bent... - JeepForum.com
post #1 of 6 Old 08-20-2013, 06:44 PM Thread Starter
243
1978 FSJ Cherokee
It sure looks like my front axle has negative camber on both sides, the passenger side more than the drivers side. I guess it's possible one of the former owners jumped it or bent the axle with some hard wheeling.
If this is true, can a frame shop put it on the rack, chain it down at the knuckles and straighten it without destroying it?
I was thinking, it may be possible to do this myself by putting some anchors in the concrete and using a floor jack.
What do ya'll think?
Dave's 78 Build
243 is offline
post #2 of 6 Old 08-20-2013, 06:53 PM
Spieg8
1984 CJ8
It can be done, but don't do it yourself (I'd put a good truss on it too). Depending how bad the camber is, it may be easier to use adjustable ball joints. If it's real bad, you should also check to make sure the shafts, bearings and seals are not taking a beating.
Spieg8 is offline
post #3 of 6 Old 08-20-2013, 07:03 PM
LumpyGrits
How much pos. camber does it show.
You can take allot out with eccentric sleeves in the upper ball joints.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #4 of 6 Old 08-20-2013, 07:18 PM
skizriz
1978 CJ7
The camber looking out of wack and being out of wack are two different things. Looking at mine last week, it looked all wonkey to me. The shop showed it at +1.
The toe was at dead ahead. Once the toe was set to 1/8" in, the camber illusion went away.
skizriz is offline
post #5 of 6 Old 08-20-2013, 07:18 PM Thread Starter
243
1978 FSJ Cherokee
It is dark now, let me try my angle finder tomorrow after work.
It has not been in for an alignment yet, I am only looking at it from a distance.
skiz, I hope it's an illusion!
Dave's 78 Build
243 is offline
post #6 of 6 Old 08-20-2013, 08:01 PM
only in a jeep cj
Use floor jack to lift each front tire and grab tire at 12 and 6 oclock, rock back and forth and see how much play is in the bearings....AND as said, toe in or out can change camber due to the lean the tire experiences during a turn.
Alignment shop first and see what they find. IF bent, Don't try it yourself as the forces involved to bend it back would require a large frame rack.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
