Looking for CJ7 sliding seat bracket - JeepForum.com
post #1 of 11 Old 04-04-2013, 07:35 PM Thread Starter
matthewleeblair
1983 CJ7
The passenger seat bracket in my CJ is a riser bracket. Doesn't leave much leg room and makes the seatbelt super tight for most folks. Anyone have one of the sliding seat brackets laying around that I could snag cheap?
matthewleeblair is offline
post #2 of 11 Old 04-05-2013, 06:14 AM
keith460
Jeep. There's Only One
keith460's Avatar
You would need to get the seat riser bracket for a YJ Jeep as they are setup in height for the sliders. CJ's did not have them on the passenger side and if you add sliders to them, the seat will sit higher than the drivers side.
1984 CJ-7 Renegade
keith460 is offline
post #3 of 11 Old 04-05-2013, 09:09 AM Thread Starter
matthewleeblair
1983 CJ7
I must not understand what I need. Right now the driver's side seat is lower and on a slider. The passenger seat is higher and on a riser (makes the seat rise up and forward but not able to slide back & forth). I want the passenger seat to be like the driver's seat. Lower and slide back and forth. So what should I be looking for?
post #4 of 11 Old 04-05-2013, 09:31 AM
1986cj
That is strange, both of the factory seats in my 86CJ slide and tip forward. I did break the paddle handle off the pass seat riser and replaced it with one from a early wrangler and it had a slider but I don't remember it setting any lower but was a direct bolt in. I have power seats in it now from a Ford explorer or I would go look.
1986cj is offline
post #5 of 11 Old 04-05-2013, 11:50 AM
Renegade82
1982 CJ7
My pass. seat didn't come from the factory with a slider. Though I have one that I plan to use on it. Keith, what are we talking in hgt. difference, 3/4"? I can deal with that. Won't be too noticeable to the untrained eye.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #6 of 11 Old 04-05-2013, 02:51 PM
BubbaK
1983 CJ7
It's at least that. I'd guess 1" -- 1 &1/4".
'83 CJ-7_258 I-6_T-4_D300_AMC20/D30_Bone Stock
BubbaK is offline
post #7 of 11 Old 04-07-2013, 08:13 PM Thread Starter
matthewleeblair
1983 CJ7
So... Any ideas what I should be looking for guys?
post #8 of 11 Old 09-26-2013, 10:07 AM
Tigerpaw
1983 CJ8
do you have pics of your seat install
I'd like to change out my old cj seats any instructions?
Tigerpaw is offline
post #9 of 11 Old 09-26-2013, 12:01 PM
dirtdudeaz
1983 CJ7
dirtdudeaz is offline
post #10 of 11 Old 09-26-2013, 03:34 PM
imafishingfred
imafishingfred's Avatar
1981 CJ7
The seat risers from my 84 both tilt forward. The drivers riser is about 1 1/4" shorter than the passenger riser. The seats and the sliders are long gone, but if I recall correctly, only the drivers side had a slider. Here are the risers.
imafishingfred is offline
post #11 of 11 Old 09-27-2013, 07:02 AM
keith460
keith460's Avatar
That's correct, only the drivers side had a slider for late model CJ's
1984 CJ-7 Renegade
keith460 is offline
