looking to buy a 84 cj 7 need help - JeepForum.com
post #1 of 6 Old 08-05-2003, 01:58 PM Thread Starter
scottbur
I am looking at a cj 7 84, with 102,000...should I but it for 2500.00 or will it just break down constantly?
scottbur is offline
post #2 of 6 Old 08-05-2003, 02:41 PM
CoryB
CoryB's Avatar
2015 JK Wrangler
Re: looking to buy a 84 cj 7 need help
Given my experience and expenditures with my 84 CJ7 so far, my initial interpretation of the thread title was a bit different than your meaning of it.
Anyway, $2500 sounds a bit steep to me, but it really depends on the overall shape of the Jeep.
Have you checked the frame and body for rust?
Does it run?
Which engine/transmission does it have?
Lift?
Tires?
How does that price compare to others in your area?
See, lots of questions before any real price decisions can be made.
CoryB is offline
post #3 of 6 Old 08-14-2003, 03:42 AM
sampson9dk
I bought an 85 CJ and if I knew then what I know now...I would have bought a pre-82 model. That on board computer (ECU)and carter BBD are crap. Pre82 didnt have the ECU and the mid 80s CJ are full of emissions and vacuum hoses.. you may even consider going around 1975 just to avoid any emission hassels. I dont claim to be an expert but consider these 2 things. Any mods could cause you major hassels depending on what state you live in. I wish someone had told me this when I bought mine.
sampson9dk is offline
post #4 of 6 Old 08-14-2003, 06:08 PM
possum
I just bought an '84 CJ7 Laredo for $3500. All original but needs some engine work and a paint job. No rust, hardtop, a/c, and new BFG tires. I think I got a deal.
possum is offline
post #5 of 6 Old 08-15-2003, 05:44 AM
mad_scientist
The carter bbd carb can be swaped for a MC2100 (motorcraft). The computer can either be ignored or bypassed (nutter).
If the engine was cared for, it should go for about 120-130,000 miles (amc 258).
. . . end transmission . . .
mad_scientist is offline
post #6 of 6 Old 08-15-2003, 02:02 PM
twmattox
The estimate on the engine life is waaaaay off. These are very robust forgiving engines. With moderate care they will last well over 200K. Mine is a AMC 150 (4-cylinder) with well over 200K. No leaks, compression checks fine, doesn't bunr oil, and runs just fine.
Regarding the MCU (computer) they are correct. These things run much better without them. Technically, you should put in an emmissions legal upgrade (Webber carb and MSD ignition will bypass all computer control and be 49 state legal I believe).
I have an 84 too. Plan on at least the following:
new wheel bearings
new u-joints
new axle joints
new tie-rod ends
new ball joints
complete brake job
drain/flush all fluids
complete tune-up
replacement of at least some seals (in engine, transmission, t-case, and axles)
possibly even a new starter/alternator/water pump
These are all parts with limited life spans and a vehicle that was most likely (partially) abused that is nearly 20 years old.
twmattox is offline
