Looking for advise on AMC 360 swap - JeepForum.com
post #1 of 7 Old 07-20-2007, 01:03 PM Thread Starter
Scott 77CJ
1977 CJ7
Found a 360 to swap in for my 304. Thinking about new intake and carb. Going to do light off roading and creek riding. Any Suggestions on card set up. Also will the fly wheel and clutch work from my 304 to the 360?
Scott 77CJ is offline
post #2 of 7 Old 07-20-2007, 01:26 PM Thread Starter
Scott 77CJ
1977 CJ7
Sorry about all the mis spells. Carb setup.advice
post #3 of 7 Old 07-20-2007, 01:31 PM
BIG REED
1977 CJ7
you could use the clutch, but the flywheels are not interchangeable (they will bolt on but have different balance)
'77 CJ-7, AMC 360, t-18a, soa
BIG REED is offline
post #4 of 7 Old 07-20-2007, 01:34 PM Thread Starter
Scott 77CJ
1977 CJ7
Thanks any advice on a flywheel. Should i buy a new one or try to find a used one
post #5 of 7 Old 07-20-2007, 01:47 PM
BIG REED
1977 CJ7
flywheel
i couldnt find a used flywheel for the 360 so i ordered a new one.
i think it was around $150
this place (a quick google) has 'em for $140
http://www.xtremeterrain.com/p84.htm
if you do find a used one, i would still have it resurfaced
BIG REED is offline
post #6 of 7 Old 07-20-2007, 03:36 PM Thread Starter
Scott 77CJ
1977 CJ7
Can anybody tell me a site where i can ford 302 motor mounts to put in a 77 CJ 7
post #7 of 7 Old 07-21-2007, 09:43 AM
bjf498
bjf498's Avatar
1983 CJ7
I was told that the 304 flywheel will work just fine with the 360. the intake is the same i know that.
Small, fine shavings are ok, large chunks are bad, huge chunks with part number stamped on them are real bad.
bjf498 is offline
Need advise....... MuddyMules Jeep CJ Forum 6 09-03-2006 10:19 AM
Advise on used Jeep SHAFT Jeep CJ Forum 4 07-20-2006 01:25 AM
84 Cj for $12,000 need advise bkeast17 Jeep CJ Forum 6 10-08-2005 03:39 PM
Looking for Advise cnixon Jeep CJ Forum 9 09-08-2005 08:04 AM
Some advise CNs CJ Jeep CJ Forum 2 06-28-2005 01:48 AM
