Looking for a 1983 CJ7 Owners Manual copy and transfer case guide - JeepForum.com
post #1 of 9 Old 12-03-2013, 01:40 AM Thread Starter
cwig12
1983 CJ7
Does anyone have an original owners manual PDF copy they could post? It would be much appreciated. Also, it's getting close to snowing here and I want to learn how to properly use my transfer case shifter (Dana 300). After I lock in the hubs is there any specific way to do things? I have a 3 speed TF999 Automatic Transmission if that makes any difference.
Thanks
1983 CJ7 Laredo
cwig12 is offline
post #2 of 9 Old 12-08-2013, 11:52 AM
Colt44
1983 CJ7
Collins Brothers, among others, has reprints of the owners manuals for various years.
I have an '83 with auto trans, too. Shifting from 2 to 4 is a little tricky.
The manual says to accelerate to a slow roll, i.e. a couple mph, put the tranny at N and then shift the txfr case while rolling.
Mine is a bit stubborn, and sometimes it wants to grind, so to get from 4H back to 2H I discovered I have to roll in reverse for a short distance, go back to D, roll forward and try it again.
Sometimes it takes a couple of tries; probably just a matter of getting 30-year-old gears to mesh properly.
If you want pdf copies of the factory service and technical manuals, PM me.
"We are all of us in the gutter...
Some of us are looking at the stars."
~ Oscar Wilde via Chrissie Hynde
Colt44 is offline
post #3 of 9 Old 12-08-2013, 02:27 PM
Colt44
1983 CJ7
I sent you a PM reply with the link to my Dropbox public folder.
You should be able to download what you need.
If you don't receive the PM, let me know and I'll e-mail it to you.
Colt44 is offline
post #4 of 9 Old 12-08-2013, 02:50 PM Thread Starter
cwig12
1983 CJ7
I got it and downloaded it. Much appreciated, thanks!
Creative-X - Web Design and 3D Printing
My portfolio:
cwig12 is offline
post #5 of 9 Old 12-09-2013, 12:15 AM
SouthernGypsy
De Oppresso Liber
SouthernGypsy's Avatar
Thanks
1983 CJ7 Laredo
I need the same thing myself...
~ SouthernGypsy's Jeeps ~
2004 Jeep TJ Rubicon 4.0L/Automatic
1983 Jeep CJ-7 Limited 4.2L/5 Speed
SouthernGypsy is offline
post #6 of 9 Old 12-09-2013, 12:34 AM Thread Starter
cwig12
1983 CJ7
Southern, I have a thread with my google docs linked to it and I put all the manuals I've compiled for open downloads. I'm uploading the Service manual he gave me earlier so it will be on there soon, here's a link.
Thread:
http://www.jeepforum.com/forum/f8/sp...-file-1770210/
Direct Google Docs Link:
https://drive.google.com/folderview?...TQ&usp=sharing
cwig12 is offline
post #7 of 9 Old 12-09-2013, 12:35 AM
SouthernGypsy
De Oppresso Liber
Oh, awesome, thanks
post #8 of 9 Old 12-09-2013, 12:44 AM Thread Starter
cwig12
1983 CJ7
Zip file should be up and ready to download which has all of the files in it.
Enjoy!
cwig12 is offline
post #9 of 9 Old 12-09-2013, 12:48 AM
only in a jeep cj
Hubs locked first going in and unlocked last coming out. The reason is so the front tires will backspin the front input shaft to help the engagement.
To go into 4 wheel drive.
With hubs locked and from a stop, engine running and clutch in, transmission in 1st gear......Try to shift. It might go right into the gear. If not, hold pressure on the shifter while you bring the clutch out ONLY to the engagement point. You want to barely move forward....like inches to a foot. It should pop right in. Make sure the 4WD light is on (if it works).
To go back to 2WD
Drive straight for 10 yards or so to relieve any binding between the front and rear axles as there is no diff action between the two. Clutch in and in first, Stop and try to shift. If it doesn't, feather the clutch out again as before and try again. Reverse may be tried and slightly turning the wheel to relieve binding.
Excessive force on the shifter is not needed either way. IF so, try another way.
After I unlock the hubs, I check it by spinning the front driveshaft by hand and checking that all is free.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
