Look at your 2150 for me..... - JeepForum.com
post #1 of 1 Old 07-13-2012, 05:20 PM Thread Starter
Caish
1987 XJ Cherokee
I've had a drive/run issue at steady speed.
Well I've tracked 90% of it down.
Seems the variable high-speed bleed system cam was stretched/worn on the
throttle shaft. #3 below.
I managed to squeeze it together enough to make it lift the needles now.
#1 below.
I got a little pop/burble now just as I open feather the throttle.
There is no information I can find on-line about this part short of.
http://tekatlarge.net/Motorcraft-215...or-Systems.php
But it gives no specs.
So if one of you that did the 2150 upgrade and is running perfect or nearly so, better if a few did it for reference.
Look in your carb at #1 above between the Venturis and open the throttle (with engine off of course) and see when it starts to rise.
Does it move at the slightest crack of the throttle or does it start moving after ??? percentage?
Caish is offline
Did I damage my new MC 2150? DesertDweller Jeep CJ Forum 15 02-20-2012 09:59 PM
Mc 2150 problems help please!!! GPW2003 Jeep CJ Forum 7 12-20-2011 08:50 PM
2150 Question Baldum Jeep CJ Forum 0 12-05-2011 01:22 PM
Motorcraft 2150 specops72 Jeep CJ Forum 12 11-15-2008 10:57 PM
304 w/ 2150 LSUtiger Jeep CJ Forum 4 02-18-2007 06:38 PM
