longer wheel studs - JeepForum.com
post #1 of 11 Old 01-25-2011, 04:30 PM Thread Starter
LimeLite
1978 CJ5
longer wheel studs
anyone know if any vehicle uses the same diameter wheel stud for late 70's cj dana 30 but has more than an inch of threads.
I just got some wheel spacers and i'm a little concerned with the engagement of the lug nuts on the front spacers (spacer to hub) I'd feel much more confident if the entire nut was on the stud, rather than seeing some exposed threads due to the stud not being long enough. Like I said, the stock cj only has about an inch of thread, the spacers are 1.5" the rear ones seem to have plenty of length, but i'm not sure if it's because of the currie rear.
LimeLite is offline
post #2 of 11 Old 01-25-2011, 05:54 PM
Alby63
1982 CJ5
Original stud part # is 610-273. You can use Dorman 610-219. They are 3/8" longer. http://www.dormanproducts.com/p-10150-610-219.aspx
'82 CJ5, glass body, 327, Holley Stealthram Pro 950 EFI, B&M Turbo350, Dana 44/30, Lockers, 3.73's, 6-1/2" lift, 35's, stainless mustang SLP exhaust
Alby63 is offline
post #3 of 11 Old 01-25-2011, 10:00 PM Thread Starter
LimeLite
1978 CJ5
sweet, thanks.
LimeLite is offline
post #4 of 11 Old 06-18-2012, 12:39 PM
kvncot
1981 CJ7
Did you ever purchase these studs? I am running into the same problem with short wheel studs on 1 1/2" spacers. I am wondering if the knurl fit well into the hubs? I had to weld my wheel studs to the rotor because they would spin and back out every time I took the wheels off pre spacers.
Easy's Good!
kvncot is offline
post #5 of 11 Old 06-18-2012, 08:34 PM Thread Starter
LimeLite
1978 CJ5
Don't recall off-hand which one's I ended up going with, I'll hafta see if I can see a number on the head of one. I do know that I had to grind the shoulder down a little because I was having a clearance issue.
78 cj-5 4" procrap lift on 35's amc304 "custom" rear bumper/tire carrier combo, rollcage...
Ex-Member of offroad nuts
LimeLite is offline
post #6 of 11 Old 06-19-2012, 08:43 AM
kvncot
1981 CJ7
I contacted Dorman and to see if they had something with the 610-273 spec in a 2 inch length. They say they don't. I may go with the suggested 610-219 but I am just trying to avoid having to weld anything to the rotors. Thanks!
Easy's Good!
kvncot is offline
post #7 of 11 Old 06-20-2012, 07:56 PM Thread Starter
LimeLite
1978 CJ5
I'm pretty sure the issue I had with those studs was if I wanted to run without the spacers on the front there was a clearance issue with the shoulder and my wheel holes, but if I ground them down slightly they worked fine
LimeLite is offline
post #8 of 11 Old 11-23-2013, 04:44 PM
br509
I used 5/8'' acorn nuts with my adaptors, the thread sticking out was a good 1/2'', but the nut that come with the adaptors are 3/4'' long, loctite, torque allgood.
br509 is offline
post #9 of 11 Old 04-28-2016, 02:03 PM
76firecracker
1976 CJ5
Thanks for the suggestion. I installed 610.219 and working great.
76firecracker is offline
post #10 of 11 Old 04-28-2016, 03:52 PM
y2k-fxst
1964 CJ6
Look at these: http://www.summitracing.com/parts/ar...7703/overview/
1/2-20 RH thread
0.625 knurl diameter
4" long
I own a Harley and a JEEP, still some people can't figure out why I'm broke!
y2k-fxst is offline
post #11 of 11 Old 04-28-2016, 06:04 PM
taklbury
1980 CJ7
Try Dorman 610-449. 1/2" 20, 1 15/16" long.
taklbury is offline
Where can I find longer REAR Wheel Studs? Wrangler1642 Jeep CJ Forum 13 04-15-2012 02:59 PM
Need wheel studs for 63 CJ5 ??? rocks4x4 Jeep CJ Forum 0 07-29-2010 11:47 PM
Longer Jeep Wheel Studs Size / Part No.? tlhigh Jeep CJ Forum 1 04-16-2009 07:42 PM
wheel studs jamesa Jeep CJ Forum 4 06-03-2006 12:00 PM
???wheel studs??? scottahicks Jeep CJ Forum 0 02-07-2003 12:51 AM
