longer brake hoses - JeepForum.com
post #1 of 21 Old 01-07-2008, 10:03 AM Thread Starter
dizz
longer brake hoses
have a cj5 4in lift and needing new front and back brake hoses.longer than stock was wondering if anyone knew of a reto fit rubbber hose like off a chevy or something that will fit.dont have the cash to buy the braided ones just yet..
dizz is offline
post #2 of 21 Old 01-07-2008, 04:13 PM
CJ Chet
Save up!!!! Don't skimp on your brakes!!
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #3 of 21 Old 01-07-2008, 04:23 PM
sanmiam
sanmiam's Avatar
1983 CJ7
I was actually wondering the same thing. While I nderstand the benefits of SS brake lines (less flex = less fade, etc etc) I personally think the extra money spent could go towards something more useful. Hell the rubber lines on there now have lasted 25 years so it can't be a safety concern. Obviously it would be necessary to properly possition them not to get caught in anything and the correct length in order for them not to tear.
And this leads us back to the original question.......
Building a Jeep is like playing golf, every now and then you get a good shot that makes you believe, hey I can do this!
sanmiam is offline
post #4 of 21 Old 01-07-2008, 05:03 PM
No_Bs
1977 CJ5
Fronts, I'm not sure about. However, a rear hose for a 1995 Dodge 1500 works great in the rear. I used one for my 2.5" lift and there is plenty there for a 4". If you go to napa's website they list the hose ends and lengths if you want to do some research. If you have a pre 80 cj5, I don't know if any other stock applications would work, it's kinda a funky end on the caliper.
1977 Cj5, 258, T-18, 2.46:1 Dana 20, 2.5" BDS lift, OBA, 38.5's. Chevy 60 frt, 14b Rear, Full hydro, 102"wb, full DOM cage.
No_Bs is offline
post #5 of 21 Old 01-15-2008, 06:33 PM
sanmiam
sanmiam's Avatar
1983 CJ7
The 79 Ford F150 hose, Raybestos BH36931, should fit 77-80 CJ's and it is about 20" long.
Found that on the web
sanmiam is offline
post #6 of 21 Old 01-15-2008, 06:49 PM
mike4089
its was only 69 dollars for russel braided front and rear lines for my cj off of quadratec...not alot of cash to know your going to stop ok
mike4089 is offline
post #7 of 21 Old 01-15-2008, 07:34 PM
petey156
1977 CJ5
you probally will pay 15 to 20 dollars each for the stock ones from advance or napa. thats 45-60$$ might as well spend a few extra bucks to get the right part.
petey156 is offline
post #8 of 21 Old 01-16-2008, 12:25 PM
Bigjeep65
1982 CJ7
I have not used these myself, but I have read in a couple different places that the Dodge Omni brake hose is a direct bolt in, and about 5" longer. Unfortunately, I don't have ant more info than that.
Bigjeep65 is offline
post #9 of 21 Old 01-16-2008, 03:02 PM
KINGJRK1974CJ5
hey man gp to 4 wheelparts and skyjacker makes them they arent cheap but i tried everything not to buy them but that what i had to do but the aresimple to put on i put 7in under mine and i had to have them good luck
KINGJRK1974CJ5 is offline
post #10 of 21 Old 04-06-2009, 05:59 PM
Rollbar
1984 CJ8
Can anyone add or confirm these applications? I am looking for a set of extended hoses for my build before I put the tub on this weekend.
Thanks,
Jim
P.S. I checked the links etc as well. I use to have a link but they must have gone out of business for extended lines that were cheaper (i.e. not paying just cause you have a lift etc) SS lines.
<----Click
<---- Click
Rollbar is offline
post #11 of 21 Old 04-06-2009, 06:28 PM
foggybottombob
Everything I've read says that rubber DOT approved brake hoses are better than stainless steel sheathed plastic hoses. I went to a local shop and had some front brake hoses made for my CJ. I think they were $30 each and they are DOT approved. Your mileage may vary.
foggybottombob is offline
post #12 of 21 Old 04-06-2009, 06:50 PM
PhatBasturd
PhatBasturd's Avatar
1976 CJ7
Originally Posted by foggybottombob View Post
I went to a local shop and had some front brake hoses made for my CJ. I think they were $30 each...
Did the same front and rear on mine. About $50 for all three.
PhatBasturd is offline
post #13 of 21 Old 04-06-2009, 08:19 PM
Shauncj7
http://www.quadratec.com/products/12706_23X_PG.htm
Both front an rear and you dont have to run around trying to find someone to make them longer, a cc and a phone and in a few days you are happy. Its cheap enough personally id just buy them and spend time you would spending playing and running around searching who and where to get them done by to doing something else. im sure other parts do will fit but how much money int he long run will you save?
Shauncj7 is offline
post #14 of 21 Old 04-06-2009, 11:02 PM
PhatBasturd
1976 CJ7
Yeah, I wish I could have back the 3 minutes it took to drive to the hydraulic shop + the 20 minutes it took them to make the lines + the 3 minutes to drive back home.
post #15 of 21 Old 04-06-2009, 11:34 PM
cmvash
1973 CJ5
You're very naive if you think others have just as much convenience to a shop as yourself.
That said, custom rubber brake lines from a local shop will work just as well as the braided steel lines. They perform the same function in the end and the rubber hoses have a long life.
However, I ordered a pair from quadratec as I was unable to find any local shops that could fab up brake lines.
cmvash is offline
where to find extended brake hoses for a 73-74 cj5? burtonboard180 Jeep CJ Forum 6 01-06-2010 02:23 PM
brake hoses petey156 Jeep CJ Forum 3 07-10-2009 12:08 PM
Longer Brake Hoses For 2.5" Lift 1974 CJ5? incynr8 Jeep CJ Forum 1 01-27-2009 07:50 AM
Replacing brake hoses! Etchandy Jeep CJ Forum 7 11-20-2008 01:32 AM
extended brake hoses jpfaris Jeep CJ Forum 7 06-06-2006 01:25 PM
