Locktite on flywheel bolts - JeepForum.com
post #1 of 5 Old 07-09-2011, 08:30 PM Thread Starter
Splinter
1980 CJ5
I removed the old manual shift flywheel from my 360 and noticed the PO had used Red locktite. There was no problem removing the studs with a 1/2 inch electric impact. I was wondering if I should use red locktite when installing the new one.
Splinter is offline
post #2 of 5 Old 07-09-2011, 08:58 PM
Badshot
I would think blue loctite would be plenty. Usually takes heat to break the red stuff loose.
Badshot is offline
post #3 of 5 Old 07-09-2011, 10:13 PM
5-90
5-90's Avatar
1988 XJ Cherokee
LocTite #242 (blue?) or equivalent is what I use. Without fail.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #4 of 5 Old 07-10-2011, 03:16 AM
L78THUMPER
2007 MK Compass
Blue
L78THUMPER is offline
post #5 of 5 Old 07-10-2011, 09:43 AM Thread Starter
Splinter
1980 CJ5
Thanks for the response guys. Blue it is.
Splinter is offline
Flywheel Inspection Cover & Flywheel Bolts kmm Jeep CJ Forum 6 09-21-2014 02:19 PM
flywheel bolts RobsCrawlin7 Jeep CJ Forum 0 06-15-2011 09:07 AM
258 Flywheel Bolts MoC Jeep CJ Forum 3 02-17-2011 12:04 AM
flywheel bolts lacpa Jeep CJ Forum 16 02-09-2010 07:50 PM
New bolts with a flywheel R&R? twmattox Jeep CJ Forum 5 01-13-2007 07:34 AM
