Locking Lug, Lost Key - JeepForum.com
post #1 of 14 Old 01-07-2012, 01:55 PM Thread Starter
al2ride
1976 CJ7
My locking lug's key grew legs and took of. The key looks pretty symmetrical. Is it possible I could get a replacement key? Otherwise, it's going to be a pain to get all four of them off.
al2ride is offline
post #2 of 14 Old 01-07-2012, 01:58 PM
BioTex
1979 CJ7
NAPA sells a socket to get them off. It has threads on the inside that are left handed and spirald inwards.
They work very well.
If you don't want to spend the money, go to a tire store. They will remove them.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #3 of 14 Old 01-07-2012, 02:33 PM
lucdog
lucdog's Avatar
1980 CJ5
Didn't know about that socket Biotex, thanks.
What worked for me. My locks had a slight taper, I hammered a impact socket on the lock. It was just a hair smaller than the diameter of the lock. This was on the last 3. The first one I ground a couple flat spots with a 4.5" cut off wheel, then the socket. There was about 80 ft.lbs of torque on the locks.
These were old and rusty rims, I wouldn't use the grinder on a good rim.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #4 of 14 Old 01-07-2012, 02:39 PM
Iceman_RNR
vice grips, all you need is the initial turn to get it loose
Why people still use those locking lugnuts is still beyond me anyways, even though back in the day I also gave it a try ... until I lost the 'key socket' also.
If 'they' really want those wheels/tires they'll get them regardless
'84 CJ7, '96 CTD, '00 TJ
Iceman_RNR is offline
post #5 of 14 Old 01-07-2012, 03:50 PM
CrazyHorse6
1979 CJ7
Any local parts store has 'em
CJ7, 258, Dana 20 T-case, Dana 30 & AMC 20, TFI Ignition upgrade, MC 2150 carb, YJ tub mod
CrazyHorse6 is offline
post #6 of 14 Old 01-07-2012, 03:53 PM
85LaredoCJ7
I have the same ones actually....mine grew legs too....tracked it back to the tranny shop.
If you need it...let me know. I'll send it. I changed lugs when I changed wheels...
85LaredoCJ7 is offline
post #7 of 14 Old 01-07-2012, 05:39 PM
mopar408
1974 CJ5
if you lived down here there are 3 people on every block that could take all 4 of 'em off in 2 minutes.
In the dark......
If it's good TO you, it's gotta be good FOR you....
mopar408 is offline
post #8 of 14 Old 01-07-2012, 07:22 PM
Area.3.Fiftyone
In the dark......
Same here in the "hood".......
I'd give it about 4 minutes though, they move a little slower round' here in the winter:
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #9 of 14 Old 01-07-2012, 07:26 PM
lucdog
lucdog's Avatar
1980 CJ5
I guess they didn't like the spare.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #10 of 14 Old 01-07-2012, 07:41 PM
Area.3.Fiftyone
Bill
They could barely fit the 4 in their lowered, fart can equipped, window tinted Honda..........
post #11 of 14 Old 01-08-2012, 06:19 AM Thread Starter
al2ride
1976 CJ7
PM Sent
al2ride is offline
post #12 of 14 Old 01-08-2012, 06:21 AM Thread Starter
al2ride
1976 CJ7
In the dark......
I hear ya. It was the same way in FL.
al2ride is offline
post #13 of 14 Old 01-08-2012, 06:24 AM Thread Starter
al2ride
1976 CJ7
Wow, those SOBs were nice to your Jeep. It looks like they even used a tire in the front end. I had the same thing happened but they only used one brick right in the middle.
al2ride is offline
post #14 of 14 Old 01-08-2012, 06:28 AM Thread Starter
al2ride
1976 CJ7
Oh man, you brought back memories from the few years I live in central FL. I used to call them coffee can roaches. It looks like they cut the springs to lower their cars and then put a coffee can sticking out the rear end to make this horrible rattling noise. It was either that or a 500 dollar oldsmobile with 2,000 dollars worth of rims and tires, and some sort of body lift.
al2ride is offline
what does a locking hub do southernjeep80 Jeep CJ Forum 15 04-26-2013 05:52 PM
Locking Hub JEBETS Jeep CJ Forum 2 09-06-2011 03:26 PM
Locking hub thord Jeep CJ Forum 1 01-26-2010 03:32 AM
locking in hubs my77cj5levi Jeep CJ Forum 11 01-04-2006 11:14 PM
Locking hub Jeepersusa.4t.c Jeep CJ Forum 2 11-21-2004 11:01 AM
