lockers - JeepForum.com
post #1 of 3 Old 01-16-2002, 10:16 PM Thread Starter
jeepster18_88
Post lockers
I recently bought an '85 cj7 with 258 and T5 tranny. What are some cheap tricks to better power from this? Also, front hubs won't disengage. This is my first experience with manual locking hubs. Is there a trick to disengaging them? How can I fix this and how will it affect it if I don't? Thanks for the help.
Josh
jeepster18_88 is offline
post #2 of 3 Old 01-17-2002, 05:00 PM
RickCJ7
Post
You just turn the hub to unlock it. If that doesn't work try taking them apart and cleaning them. A cam, 4 barrel intake and 390 cfm Holley will make it run almost as good as a 304. But a 360 would be a lot faster and cost about the same.
Rick OIIIO
RickCJ7 is offline
post #3 of 3 Old 01-17-2002, 05:50 PM
rivertrout10
rivertrout10's Avatar
Post
Jeepster - "cheap" is a relative term - what is cheap? Not knowing your definition I will make some broad suggestions:
1 - Depending on the type of carb (assuming you have a carb)you have you may want to do an upgrade here. The carter (stock) is junk - look at Weber ($350ish) if you want to stay with a carb or Holley Projection ($500ish).
2 - Exhaust - if you still have the stock manifold suggest a hedder - depending on type you can spend from $200ish to $500ish. Suggest a dual outlet hedder vice a single outlet hedder. Borla or flowmaster mufflers are good ones.
3 - Depending on your state laws (not sure about TX emissions requirements) you may be able to remove some of the smog stuff - catalytic converter, etc.
4 - K&N air filters are touted as the cats meow in regard to air filters - I dont have one on my Jeep but do in my BMW - cant really say there is the advertised difference - I do know people who swear by them however.
Good luck,
Derek
Jeep - its a job - not an adventure
rivertrout10 is offline
Here we go again....lockers = )) CJ7_Jim Jeep CJ Forum 20 04-11-2009 03:30 PM
best lockers gublube Jeep CJ Forum 5 10-01-2007 12:23 PM
lockers snoogans Jeep CJ Forum 5 09-01-2007 10:52 AM
Lockers Cambo Jeep CJ Forum 5 08-08-2007 09:14 PM
lockers? petey156 Jeep CJ Forum 18 07-26-2007 07:02 PM
