Lockers? - JeepForum.com
post #1 of 9 Old 09-24-2011, 09:01 AM Thread Starter
Gido
1980 CJ7
Lockers?
Hey y'all! I am about to get my first jeep. A 1980 cj7. The rear end is out and I need to get it fixed. I want to do some moderate things to it so I can drive it on the road and trailer it with the family to some moderate trails. I am thinking about a locker in the rear end since I have to get it rebuilt do I need a locker to traverse moderate trails or can I get by without one.
Thanks
Garret.
"At first you don't succeed, get a bigger Hammer!"
in memory of Jimmy Smith - a wise man
Gido is offline
post #2 of 9 Old 09-24-2011, 10:02 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Many have done amazing things with an open diff. It all depends on what kind of trails they are, too. Rocky trails, mud, etc, you may want them. Wooded trails with tight turns, maybe not.
Get a selectable locker, best of both worlds!
Rick
Cutlass327 is offline
post #3 of 9 Old 09-24-2011, 10:07 AM
Transorange
1979 CJ7
If you have an AMC20 I would just go with some 1-piece axle shafts and a lunchbox locker... (lockright or aussielocker)
Should be all you need for simple trails. Oh and maybe welding the axle-tubes as they tend to rotate if the stock weld-spots crack.
Jeep CJ7
350sbc, SOA, Fiberglass body, 35s
Transorange is offline
post #4 of 9 Old 09-24-2011, 10:57 AM Thread Starter
Gido
1980 CJ7
Thanks! I don't know for sure what kind of trails yet but prolly a combination of all. Nothing extreme. I am on a budget so a simple solution will be best but I dont want to sacrifice drivability. I was leaning towards some sort of locker just didn't want to spend a ton of money. Thanks again.
Gido is offline
post #5 of 9 Old 09-24-2011, 11:59 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Well, it also depends on where you live and how much you'll be driving it. Personally, I drive mine as my DD, year-round, so I don't want a locker or even an L/S in the rear of mine, knowing how easy a short wheel base vehicle like a CJ can just decide to spin out on ice. This is why I suggest a selectable locker. Normal driving you can have open axles, but if you see yourself getting into a situation, you can flip that switch and be locked in and ready to go.
And yes, I highly recommend the 1-piece axles for anything other than an open diff..
Rick
post #6 of 9 Old 09-24-2011, 12:04 PM
brownbagg
1930 MK Compass
the aussie locker is a pretty good locker, simple to install and hard to destroy. I have two in mine. bought them for $258 each
brownbagg is offline
post #7 of 9 Old 09-24-2011, 12:06 PM
jumbojeepman
1976 CJ7
Before you get a lunchbox locker you should disassemble the old carrier and make sure it's still good. When I took mine apart there was too much wear on one of the side gears, and you can't get a new open carrier (at least I couldn't find one when I was looking, and I called everyone.) Besides, a Detroit locker was about the same price as an Aussie Locker + a new carrier would have cost. Due to Aussie Locker's return policy, it was easier to sell it on eBay than to return it.
jumbojeepman is offline
post #8 of 9 Old 09-25-2011, 05:33 AM
bigredisb
1979 CJ7
Just be sure to plan on one piece axles if you are going to run a locker. Its not worth tearing apart the rear end and installing new parts just to snap an axle on your first trip out.
Personally I am running lunch box lockers front and rear and I am on the street more than I like to admit. I don't notice much of a drivability issue at all, I don't drive my Jeep in the winter however which would make the decision to go selectable a no brainer.
1979 CJ7 aka "Christine" Build Thread:
2013 Rubicon Unlimited build thread:
bigredisb is offline
post #9 of 9 Old 09-25-2011, 07:44 AM Thread Starter
Gido
1980 CJ7
Awesome info! Thanks. I live in north Florida so I will be dealing with sand, mud and clay and the occasional rock. I will be driving it on the street prolly more than on the trails but a capable jeep on the trails is what I am looking for. So, it looks like one piece axles and aussies or lunchboxes for me. Thanks again.
Gido is offline
