Locker Kits - JeepForum.com
post #1 of 3 Old 06-19-2002, 09:28 PM Thread Starter
Jwhit
Jwhit's Avatar
Post Locker Kits
I am thinking of upgrading my axles with lockers. I run 33s on a modified suspension. The axles are stock unforunately. The front axle has warn hubs and I was thinking a detroit soflocker would do the trick. I want to keep the rear axle free for road use and not so much noise on the road. I thought of gettting an air loacker system. (ARB?) Will the full time detroit lockers in the front mix with the air lockers? Is it a good idea to change gear ratios seeing as I used to have 30 inch tires on there and now I have 33's?
'85 CJ7 Rebuilt 258/T5/Dana 300 Mopar MPI fuel Injuection kit - 35" Pro Comp X-Terrains,one piece rear axle, 4.56 gears, Tracloc rear, Detroit Nospin front, 2" Full-Traction Shackle Reversal, 1" body lift, 2.5" Sky Jacker lift
'05 Jeep "Willys" ~stock... daily driver
Jwhit is offline
post #2 of 3 Old 06-23-2002, 11:06 AM
80cj
80cj's Avatar
1980 CJ5
Post
Jwhit--
I guess your idea should work. Don't know what kind of four wheeling you do but a very effective limited slip for your front (which I assume is a Dana 30) would be a Dana/Spicer Powr Lok or a Tru Trac. The Powr Lok has 4 spider gears and would do much to beef up your front diff while still being reasonable smooth. Unless you do extreme rock crawling where your front wheels get off the ground, a good limited slip should serve you well. Don't know what your existing gear ratio is but lots of people who run 33's find 4.10 a good ratio to run. Wish I could afford an ARB air locker for my rear.
80cj is offline
post #3 of 3 Old 06-27-2002, 11:20 AM
jeeperzcreeperz
Post
Jwhit
Im just curious what year jeep you have with your 33's and how is the over all gearing with 33's and stock gears? how is it for freeway crusing, and how about for off roading? Thanks.
75 CJ5 In process of restoration.
Metalic blue, Dana 44 Dana 30, 33 12.5 15 on 589's. Ford T18 4 speed, Dana 20 case. Upgraded to AMC 258 with Howell fuel injection, 4 ponit cage.
jeeperzcreeperz is offline
80' CJ 5 Locker Kits swampus Jeep CJ Forum 2 03-17-2009 04:58 PM
t-176 rebuild kits which one? JeepnBlake Jeep CJ Forum 4 08-15-2008 08:57 PM
CJ SOA kits. spk454 Jeep CJ Forum 5 08-26-2007 05:20 PM
ARB Locker verses Electirc Locker. dawgates Jeep CJ Forum 10 10-04-2005 11:26 PM
Hardware kits 76 vs. 78 and on SQF1 Jeep CJ Forum 0 05-18-2005 11:20 PM
