locker break axle? - JeepForum.com
post #1 of 6 Old 04-04-2007, 10:25 PM Thread Starter
bulljeeper
bulljeeper's Avatar
locker break axle?
i have a 30 up front a 44 in the back...if i lock them will 33 or 34 inch tires be too big for the axles to support them...oh i got a 258....and has anyone used the aussie locker in the rear of a daily driver...an help wold be greatly apprectiated
bulljeeper is offline
post #2 of 6 Old 04-05-2007, 04:13 PM
BLS33
Chief of the brain police
BLS33's Avatar
Why would you want lockers in a DD?
BLS33 is offline
post #3 of 6 Old 04-05-2007, 04:52 PM
Bard
I wouldn't lock the front personally. Open and a winch is a better set up. The Dana 30 isn't so kind when locked even with 33"s. It is all driver in this case. I would lock the rear in a DD, Aussie is a good set up.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #4 of 6 Old 04-07-2007, 07:46 AM
dave_dj1
i have lockrights in the front and rear, it's not a dd however i do drive it to and from the trails sometimes, i would NEVER lock the rear of a dd with one of these, very similar to the aussie, they are just too squirrely on the street. it wants to change lanes everytime you shift. my .02
dave_dj1 is offline
post #5 of 6 Old 04-07-2007, 08:19 AM
evil-ant
33" or 34" tires are fine, with the dana 30 you can go up to 35" tops if your nice to it and drive normal, the dana 44 you can go up to 37" tires and be fine if you drive normal. It's when you start full throttling it up rock gardens and hills that you'll run into axles breaking, for the dana 30 it will be the driverside, the longer shaft will twist more and push the shaft to it's limits. One of my friends has a cherokee with 35" x terrains, nothing broken all year, the other friend has 36" tsl's, snaps shafts every time. But the guy with 36" tsl's has a front locker and drives it like he stole it, so it's expected.
evil-ant is offline
post #6 of 6 Old 04-07-2007, 09:56 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I have no problem running locked front and rear on a Daily Driver. Matter of fact, my CJ5 has 33s and a rear Detroit. I'm currently rebuilding the front D44 and it'll probably get a Lockright. Once you wheel locked up, you'll never go back. Sure, the occasional "bang" when the rear locker unloads, a little squirrely on ice and you need to coast around corners but who cares.. it's a Jeep.
BESRK is offline
Need help to determine carrier break on Detroit locker jode Jeep CJ Forum 11 04-20-2016 12:04 AM
Cj5,Axle swap, won' break sufficent.... Moonmulligan Jeep CJ Forum 3 09-03-2009 09:23 AM
tire size before axle break BlueFalcon Jeep CJ Forum 5 07-19-2007 07:53 AM
Which axle benefits most with a locker panzer948 Jeep CJ Forum 4 05-30-2006 10:17 AM
no-slip locker and one pice axle? romans111 Jeep CJ Forum 2 10-09-2004 12:25 AM
