lock-right lockers in the Snow? - JeepForum.com
post #1 of 11 Old 10-27-2003, 03:37 PM Thread Starter
NJCJ7
NJCJ7's Avatar
I keep hearing things like "lockers are tricky in snow" or "take getting used to in snow". I can adapt, so i am not too worried, as long as the bottom line is still improved traction in the white stuff... is it? Any general commentary on lockers like lock-right, aussie lockers, detroit ez etc in the snow is appreciated....
1985 CJ7 MC2100,TFI, 2.5" BDS suspension, Full Cage, 31" Mud Tires, 1/2" MORE shackles, Aussie Locked AMC 20
NJCJ7 is offline
post #2 of 11 Old 10-27-2003, 05:37 PM
rustyCJ
this is pretty simple if you think about it. without lockers one tire stays relatively still while the other spins. that one "dragging" tire helps keep the rear from sliding sideways. with a locker both tires spin so there is no "dragging" tire to hold the rear still so it will slide sideways.
ever seen a long burnout tire mark that is only one tire(no posi/locker), notice how its pretty straight. ever seen a long burnout tire mark that is two tires(posi/locker), notice how it usually zigzags sideways?
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #3 of 11 Old 10-27-2003, 06:51 PM Thread Starter
NJCJ7
NJCJ7's Avatar
That makes sense... so open diffs in 4wd are okay in the snow? I just noticed some lack of traction with the current setup (of course i was trying to scale a boulder with the other tires on wet grass) and want to improve it, but with winter coming, snow traction is my top priority...
NJCJ7 is offline
post #4 of 11 Old 10-27-2003, 07:09 PM
Lightningdon
Lightningdon's Avatar
One thing I noticed with my Cherokee....the tail would fishtail like mad if you tromp a little too much on the go pedal, but if in 4WD, you still run pretty much in the direction you point your wheels. You do have to be a little careful, though, especially if not in 4WD, 'cause you'll do a 360 in a heartbeat!
'97 TJ
'75 CJ5 304cid, t18 tranny w/granny low, model 20 T Case, DANA 44 rear, 30 front, 4" suspension lift, 33" tires, in need of more work!
"The only thing necessary for the triumph of evil, is for good men to do nothing." (Edmund Burke)
Lightningdon is offline
post #5 of 11 Old 10-27-2003, 07:48 PM
rustyCJ
lockers do nothing for traction, that is the tires job. a lockers job is to turn both tires regardless if they have traction or not. spinning a tire in wet grass is usually a sign of bad tires.
so if you are thinking about lockers for better traction you are looking into the wrong thing, you need better tires. a locker with bad tires will just make both tires spin instead of just one.
rustyCJ is offline
post #6 of 11 Old 10-27-2003, 08:01 PM Thread Starter
NJCJ7
NJCJ7's Avatar
Bad like old? Or bad like not optimized for off road? My tires are new, but i don't think the previous owner had wheeling in mind when he got them...
NJCJ7 is offline
post #7 of 11 Old 10-27-2003, 08:56 PM
DustinsCJ7
DustinsCJ7's Avatar
What kind of tires are you running?
P.O.S Jeep club member #2
84 CJ7 nuttered up, TFI'ed, MC2100 conversion, 2" spring lift, 31" BFG MT's
79 LUV 4x4
Live like there's no tomorrow
DustinsCJ7 is offline
post #8 of 11 Old 10-27-2003, 09:03 PM
overlander
Well, it might not matter what tire you have if 2 of them are in the air. When climbing an obstacle such as you mention it tends to unload 2 of the tires while placing all the weight on the other two. It won't matter what tire you have then if the differentials are open. A limited slip or locker is one answer, a more flexible suspension is another.
Some obstacles cannot be overcome in this scenario as even with a locker the available traction to the tires with traction will not be enough and they will spin.
overlander is offline
post #9 of 11 Old 10-28-2003, 06:55 AM Thread Starter
NJCJ7
NJCJ7's Avatar
Futura (pep boys??) Dakota A/T's
NJCJ7 is offline
post #10 of 11 Old 10-28-2003, 10:29 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
I've noticed teh sliding thing but usually in the corners.
So, don't apply power in the corner, that simple.
You get used to it very easily.
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #11 of 11 Old 10-30-2003, 08:22 AM
MR.CJ-7
I have my lockrite in the front. No problem. If it is really, deep or icy my jeep has a slight tendency to crabwalk to the right a little, but not a problem, especially when you weigh all the benefits of a locker!
Get the lockrite--you'll be happy!
Former CJ'er
MR.CJ-7 is offline
snow covered roads and lockers joes1982CJ Jeep CJ Forum 13 12-04-2009 07:33 AM
Front locker, only lock one hub in the snow? CJATE Jeep CJ Forum 4 04-24-2009 08:25 AM
Popping noise when steering lock to lock DT5150 Jeep CJ Forum 15 07-07-2008 08:55 AM
Lock right Lockers jeepnut00 Jeep CJ Forum 11 02-20-2007 02:45 PM
lockers 83 cj-7 258 Jeep CJ Forum 3 06-26-2004 06:03 AM
