liquid check = rollover check??? - JeepForum.com
post #1 of 22 Old 03-22-2008, 03:25 AM Thread Starter
meater
1981 CJ8
Soooo,
i need to replace my liquid check valve. George's seems to be the only answer to this fix (aside from plugging the hoses).
According to him:
the liquid check valve is no longer in circulation.
the rollover check valve does the same thing as the liquid check valve.
the fix: install two rollover check valves in place of the LCV & original RCV.
My problem with that answer:
It is my understanding that the liquid check valve behaves differently from the rollover check valve. They are not the same valve.
My question:
Can I replace my LCV and RCV with one RCV and have my system run smoothly?
meater is offline
post #2 of 22 Old 03-22-2008, 06:51 AM
Bard
Well I needed new seals for my 20 gallon tank and during the inspection, I saw one of the rollover checkvalves was cracked, so I decided to replace both of them. I went to the dealer to see if they had them. It turned out when you type in 1985 CJ7 they were discontinued, when I told the parts guy to write down the number and crosscheck it with a 1994 Wrangler YJ, they are the same part numbers. I didn't think about the liquid check valve, but I am sure they are close enough to the same.
Try this number at a dealership -
J319 8666 Check Valve
They are different types of valves and you can not run them like you suggested. You need the correct ones or just bypass the LCV.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #3 of 22 Old 03-22-2008, 07:13 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
They serve different purposes. The roll over valve closes when the vehicle is upside down. The liquid check valve closes when it fills up. It works more like a carburator's float system. It has a needle/seat in it. It stops fuel from leaking out the vent line during off camber situations (like steep climbs). I took one of these magic valves apart a couple weeks ago.. just had to see what made it tick.
BESRK is offline
post #4 of 22 Old 03-22-2008, 08:43 AM
Mike Romain
I have only been using the roll over valves in the tank and have my canister relocated up by my brake master to keep it's air filter out of the mud. I run sand pit and ravine walls and haven't had any gas getting to my canister, well no fumes anyway. I also have had it rubber side up sideways twice on the canister side and had no gas leaks.
Maybe I have been lucky or just don't overfill my gas tank or just don't run steep stuff with a full tank? Or maybe my raised canister does the trick?
Mike
Mike Romain is offline
post #5 of 22 Old 03-22-2008, 11:29 AM
jscherb
Jeep discontinued the use of the liquid check valve after the CJ - the YJ only has the rollover check valve. I believe in the YJ they are mounted on top of the tank, just like in the factory 20-gallon option on the CJ.
Seems to me as long as the rollover check valve is mounted high enough above the top of the tank to prevent liquid fuel from flowing through in high-angle situations, you might decide to run without the liquid check valve, just like the YJ, although you should know what your local emissions and inspection regulations are before making any changes to the system.
Don't run without the rollover check valve, especially if you drive off-road and are at any risk of rolling over.
jscherb is offline
post #6 of 22 Old 03-22-2008, 11:34 AM
fuzz401
1978 CJ7
http://smg.photobucket.com/albums/v1...ystem_jeep.jpg
and I have this for sale also if needed
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #7 of 22 Old 10-29-2015, 10:22 PM
258
Cj
Hi, I am pretty hands on. Can I rebuild the LCV in some way? Is it problematic to open it up to do this?
258 is offline
post #8 of 22 Old 10-30-2015, 02:08 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
You may get more responses if you start a new thread, instead of resurrecting a 7 year old one.
Matt
Matt1981CJ7 is offline
post #9 of 22 Old 10-30-2015, 04:56 AM
keith460
Jeep. There's Only One
keith460's Avatar
Comes apart easy as long as you are gentle with prying the top lid off. I had taken mine apart as well to clean it out of old gunk that might have been in there and it was easy. Just be careful you don't damage any of the inside components are LCV are as rare as fine art.
1984 CJ-7 Renegade
keith460 is offline
post #10 of 22 Old 10-30-2015, 06:42 AM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
This post in my build thread has several photos of what to expect if you open the thing up.
As Keith mentioned, it's not difficult to open if you are gentle with it and understand how it fits together.
Here are a couple of photos from that post:
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #11 of 22 Old 10-30-2015, 08:22 AM
Mortgage-payer
1976 CJ7
Option 2:
Buy the all in one replacement from MTS;
http://www.mtscompany.com/miscjeep.htm
I've been happy with mine.
I call it a distributor, not a dizzy.
Mortgage-payer is offline
post #12 of 22 Old 10-30-2015, 08:34 AM
texasdave
texasdave's Avatar
1980 CJ7
^^^^^MTS has them
texasdave is offline
post #13 of 22 Old 10-30-2015, 09:17 AM
Matt1981CJ7
1981 CJ7
Originally Posted by Mortgage-payer View Post
Option 2:
Hmm...not sure what you mean by "all in one".
The MTS diagram shows 2 different parts for the LCV and RCV.
Matt
post #14 of 22 Old 10-30-2015, 10:19 AM
258
Cj 20 Gallon - valves
AWESOME, I can do it! Exactly what, if anything, do I need to replace inside . . . or just do a THOROUGH cleaning of those internal parts?
Do you recommend replacing the Emission Valve at tank top or simply blowing it out with air? There are TWO valve's up there right? Should I NOT touch the EMV and/or should I at least replace the 2 grommet's? I believe they are both the same grommet.
258 is offline
post #15 of 22 Old 10-30-2015, 10:25 AM
258
Cj
Great images, THANKS!
So, is their junk inside it when it is first opened? Does that center rubber coin-shaped piece need replacing?
258 is offline
Has anyone used this liquid check valve? 4XGore Jeep CJ Forum 1 03-27-2009 08:51 PM
liquid check valve BOHUNTR1986 Jeep CJ Forum 6 07-29-2008 08:26 PM
Liquid Check Valve longlimb Jeep CJ Forum 19 11-11-2006 09:13 PM
Rollover Check Valve & Fluid Check Valve -Parts search CJPoorhouse Jeep CJ Forum 2 06-13-2004 07:13 PM
liquid check valve uglydoug Jeep CJ Forum 3 04-25-2004 04:25 PM
