Lil Red CJ5 Log - Page 4 - JeepForum.com
post #46 of 115 Old 07-12-2013, 12:40 AM Thread Starter
roboto65
1976 CJ5
Yep will do on the video. I have not called them yet but will next week when I place my order for my parts just hope the crack does not cause any problems till I find that 360 LOL
They say money can't buy happiness but it can buy Jeep parts...and Jeep parts make me really Happy.
roboto65 is offline
post #47 of 115 Old 07-18-2013, 10:19 PM Thread Starter
roboto65
1976 CJ5
Saw a axle on CL says it is a dana 30 why no locking hubs. I have drums on mine and was looking for an axle with disc brakes would the parts on this axle work?
I have other pics but kinda hard to do stuff on my cell phone lol
roboto65 is offline
post #48 of 115 Old 07-19-2013, 01:26 AM Thread Starter
roboto65
1976 CJ5
Would a quadtec have lock out hubs in the front ?
roboto65 is offline
post #49 of 115 Old 07-19-2013, 06:02 AM
MoC
They would have drive flanges. No locking hubs unless someone added them after the fact.
MoC is offline
post #50 of 115 Old 08-12-2013, 07:46 PM Thread Starter
roboto65
1976 CJ5
Ok well going to throw this on here to get opinions now I do know the 360 has more power but the 304 presented it's self so I have no problem rebuilding it and running it and going to guinea pig it a little with Shawn with the cam which I am looking forward to.
Anyhow to the point this question pertains to the 304 but it is an any engine question as it deals with cylinder measuring and what do I do with what I have.
I do not have a problem boring this but why if it is not needed why waste money.
Ok now the long part PS I tried putting the numbers apart but when I post it they are jumbled back up sorry.
Here are the measurements of each cylinder top mid and bottom mind you was attained with telescoping Ts and a vernier caliper digital also took 2 measurements 90 degrees apart so one vertical and horizontal
#1 T 3.765 3.765
M 3.751 3.758
B 3.752 3.752
#2 T 3.762 3.756
M 3.753 3.752
B 3.755 3.751
#3 T 3.756 3.758
M 3.753 3.753
B 3.752 3.750
#4 T 3.761 3.764
M 3.755 3.755
B 3.751 3.755
#5 T 3.765 3.756
M 3.754 3.755
B 3.757 3.755
#6 T 3.756 3.758
M 3.752 3.755
B 3.755 3.753
#7 T 3.765 3.759
M 3.757 3.755
B 3.756 3.757
#8 T 3.769 3.769
M 3.757 3.757
B 3.755 3.759
Sorry lots to look at but was a little work to get that but worth it just wondering what do you gurus see the least I can bore would be .020 or if I just honed to straighten then go back with stock or would the honing remove to much?
Also did not ridge ream this so that may have thrown it off but there was not much ridge at all by my finger feel anyway mostly carbon.
roboto65 is offline
post #51 of 115 Old 08-15-2013, 11:00 AM Thread Starter
roboto65
1976 CJ5
Well stuck the good block in the machine shop yesterday by the time I am done I will have a new motor it looks like hate half doing something so it looks like a full rebuild of a 304. I will get some pics up soon.
roboto65 is offline
post #52 of 115 Old 08-15-2013, 04:48 PM
Jeeper44mag
1978 CJ7
Sweet!
Black '05 LJ, soft top, ~4" lift, 42rle, 3.73, 35"x12.5" AT's, Tampa FL area
Jeeper44mag is offline
post #53 of 115 Old 08-27-2013, 06:01 PM Thread Starter
roboto65
1976 CJ5
Ok well stuck on the boat but machine shop called .030 over on the pistons and .010 under on Mains and rod big ends got the pistons ordered. One question where would you take weight off the rod if say we are weighing everything and getting things close on weight and balance.
roboto65 is offline
post #54 of 115 Old 08-28-2013, 09:32 AM Thread Starter
roboto65
1976 CJ5
Well just got off the phone with the machine shop got out cheaper than Matt but dang 700 dollars later LOL Oh well cannot take it with ya and I will have a new rebuild.
roboto65 is offline
post #55 of 115 Old 08-31-2013, 01:54 PM
WSS
WSS's Avatar
1972 CJ5
Originally Posted by roboto65 View Post
Oh well cannot take it with ya.
What? The Jeep or the money??
WSS is online now
post #56 of 115 Old 09-06-2013, 09:20 AM
Jeeper44mag
1978 CJ7
Keep us updated!
Luis
post #57 of 115 Old 09-06-2013, 10:32 AM Thread Starter
roboto65
1976 CJ5
Still stuck on the boat but pistons at the house and need to pick up the stuff at the machine shop when I get home hopefully will start the rebuild and take plenty of pics and maybe a write up on a 304 build starting from fresh. So ready to get this Jeep moving again even if it just drives around the complex LOL
roboto65 is offline
post #58 of 115 Old 09-12-2013, 06:19 AM Thread Starter
roboto65
1976 CJ5
Well did a little work today have parts coming to do the front disc upgrade. So off with some parts and clean stuff up.
Passenger side
Drivers side
Spacer off next the drum
Oops looks like we have a leak no problem there will be a caliper there soon.
Hub with the lock ring you have to remove after you undo the 6 or 5 allen head screws on the cover that holds the switch depending on what year you have, remove the lock ring and the Locking hub should slide off
This is what you see next bend the washer back and well mine was finger tight.
After you take that one off there will be another right behind it unscrew it and well off comes the hub.
You should be able to pull the axle at this time so do it LOL you will see this nut which is the lower ball joint and it is an 1 1/8 loosen it almost all the way and it should look like this.
Did not get a pic of the Top nut on the ball joint but it is 1 5/16 nut now when you get a new ball joint it will come with the castle nut so I just loosened mine so the top was flush with the top of the threads and whacked it real good with a hammer and popped right off.
The once you remove the knuckle you will be left with this.
And this is a shot of the adjust split nut for the ball joint preload have to find that tool myself.
Anyhow there you are disassembly of the whole shebang next we will put it all back together. Stay tuned
roboto65 is offline
post #59 of 115 Old 09-12-2013, 08:28 AM
bradleybrb
1975 CJ5
Looks good, you are gunna love the disc brakes up front.
bradleybrb is offline
post #60 of 115 Old 09-12-2013, 09:16 AM Thread Starter
roboto65
1976 CJ5
Well dang unless someone has a source for shims for a 1976 Warn hub guess I am going to have to foot the money for new hubs the money pit continues LOL well cannot take it with you just delays putting them back on.
The Shim and found other pieces that are in the pic
And the bearings think these can be cleaned and put back in no problem there.
Warn says they do not carry parts as they discontinued them 30 years ago and they no longer use bearings there from what he said.
roboto65 is offline
