lights and wiring HELP! - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > lights and wiring HELP!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff Axle Simple Swap Kit!Nitro Gear Packages Now Available at Rockridge 4wd
Unread 05-24-2011, 08:06 PM   #1
sheltc
Just bought my 79 cj5. It is in reasonably good condition, but I was driving it last night and the lights were cutting off and on! A guy I work with said that the floor dimmer switch was bad for going out and causing this. Any truth to that? I hate tracing wiring!
sheltc is offline   Reply With Quote Quick reply to this message
Unread 05-24-2011, 08:10 PM   #2
benullman
1981 CJ7
I would replace it. For $6-7 it usually wears out with all that voltage passing through it
Ben
[QUOTE=Gregg79CJ7304;11634021]Great minds think alike, but so do serial killers......Thanks.[/QUOTE]
benullman is offline   Reply With Quote Quick reply to this message
Unread 05-24-2011, 09:48 PM   #3
JeepHammer
Running On Empty...
1973 CJ5
Ben
Right Idea, Wrong Reason.
Somewhere between 12 and 14 volts are all that passes through a dimmer switch,
What kills them is the AMPERAGE they have to deal with when the connections are made and broken internally.
The AMPERAGE is what kills the contacts.
You were VERY close!
Most people think they die because people yank or stomp on them too hard!
The last one I changed must have had an ounce or more of mud in it when I took it apart!
No wonder they only last about a year for me...
The dimmer switch usually goes out because it's on the floor board and gets a TON of abuse from dirt, moisture, ect.
The switches in the GM columns are too small to do the job correctly, too small of contacts for the current they have to deal with,
And the contacts are made from the wrong stuff to live...
Along with all the dirt, dust, moisture, mouse poop, ect that gets into them.
Consider putting your head lights on Relays so a lot of current doesn't have to go through those already overworked switches?
JeepHammer is offline   Reply With Quote Quick reply to this message
Unread 05-25-2011, 12:06 AM   #4
lucdog
lucdog's Avatar
1980 CJ5
Don't cheap out on the dimmer switch. Get a good one. I have used the BWD with good results. While your at it, run a ground from the battery to the lights.
Bill
1957 WILLYS pickup, needs work.
1973 J 4000,
1978 CJ7 DD.
1979 CJ7 360, TH400/Quadratrac trail Jeep.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7 pretty weekend and sometimes to work Driver in the summer, My first rebuild, if the Q-trac and 5 are broke, this one is the one to take. its just as capable as the other 2, except nice paint.
1984 Grand Wagoneer, 1 ton axles, great 360/727, and a big a$& tree fell on it .
1989 YJ the CJ to YJ conversion.
2005 TJ Rubicon.
2011 Grand Cherokee Laredo 4x4, Mrs. LUCDOG's DD.
Lots of parts not for sale, i'm a hoarder.
lucdog is offline   Reply With Quote Quick reply to this message
Unread 06-06-2011, 10:59 AM   #5
sheltc
Thanks for the advice. I figured it out. It was the actual headlight switch. Now does anyone know what a good website to order parts from would be
Unread 06-06-2011, 11:21 AM   #6
benullman
1981 CJ7
paraphrasing gets me in trouble
I knew it was amperage I just wanted to get that in before I left.
I dont know why they made them the way they did. they could have easily hooked them up to a relay
Ben
