lifts - JeepForum.com
post #1 of 2 Old 05-30-2004, 11:36 PM Thread Starter
83 cj-7 258
83 cj-7 258's Avatar
lifts
I'm thinking of which lift i should get for my 83 cj. All i want is 2-3" lift. Add a leaf kits a tempting because they a cheaper and add 2", does any one know anything about them. When I do lift my jeep do I need to get a dropped pitman arm, new sway bar links, t case lowering bracket, or any other stuff. How big of tires could i fit with a 2-3" lift. THANKS!
83 cj-7 built Chevy 350, sm420, dana 300. Superlift 4in lift, 33x12.50 mikey thompson mtz.
83 cj-7 258 is offline
post #2 of 2 Old 05-31-2004, 06:55 AM
jadams68
jadams68's Avatar
With a 2.5" lift kit, you can toss 33" tires on your jeep. I'd suggest at the same time, that you put a 1" body lift in there to give it the perfect height.
Many companies make a 2.5" suspension lifts. Add a leaf is fine, but why not spend a couple extra bucks and replace those tired, old springs?
A 2.5" kit will not require a drop pitman arm or a t-case lowering kit. You won't need to replace the sway bar links either.
Look into Skyjacker softride, BDS and Rubicon Express for 2.5" kits.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
Are there light duty 4" lifts and heavy duty 4" lifts yojeep79 Jeep CJ Forum 2 08-21-2009 09:19 AM
cj lifts spoonkilr Jeep CJ Forum 9 05-11-2009 02:38 PM
lifts ??? a2tripp Jeep CJ Forum 2 01-24-2009 07:01 AM
All RE Lifts 2005BlackRubi Jeep CJ Forum 4 12-15-2008 02:07 PM
What do you'll think about shackle lifts? What is "acceptable"?+?'s about other lifts jeepcj7 Jeep CJ Forum 3 03-20-2003 08:36 PM
