lifting ?'s - JeepForum.com
post #1 of 4 Old 03-19-2003, 06:03 PM Thread Starter
rwcloukey
lifting ?'s
My cj already had a 2" shackle lift when I bought it. Im interested in doing 4"suspension. #1. Is this difficult? what might I get caught up on? #2. With the total at 6" will I need to make any other adjustments? ie. dropped pitman arm, dropped transfer etc....? thanks for the help!
81 cj7.
I6
herced tub
diamond dash
rwcloukey is offline
post #2 of 4 Old 03-19-2003, 08:04 PM
JeepingMoose
Hey! Welcome aboard!
My rig, like yours, came from the previous owners with a 2" shackle lift...no fun on the street, as it changed the caster angle for the front axle and promoted wandering on the street! I ditched it quick-like!
I went with a 2 1/2" lift as I wanted no larger than 33's in the future. My conversion was very easy and went well. Make sure you have a cement work surface, a floor jack, good jackstands,and an assortment of hand tools. My spring bushings were semi-seized and required a few major grunts on my part to loosen and remove. I went with extended brake lines even though they weren't required. On the 4" lift I believe extended brake lines and a dropped pitman arm are requred, as well as lowering the transfer case. All the required parts SHOULD be included in a quality kit.
All in all I am happy with my lift (Skyjacker), as my ride quality improved marginally and my articulation improved two-fold.
If I were to go with 35's,I would definately use a 4" lift OR a 2.5" and some judicious fender trimming (this option keeps your center of gravity down).
Remember if you go with larger tires, compensate with correct diff gearing!
Good luck with your wrenching, and welcome aboard...again!
'76 CJ7 w/'83 258 ci w/MC 2150 carb, T150, Dana 20 T-case, 30F/AMC20 rear, stock gears, 31" Armstrongs, 2.5" Skyjacker, Bestop soft top...all in all, a work in progress!
New Purchase March 2003:
1976 J20-Built 360 w/Jacobs electronics, T18 tranny, Dana 20, D44 front, D60 rear, 3.73 gears, Detroit in rear...all for $475!!!! YeeHaw!!!
JeepingMoose is offline
post #3 of 4 Old 03-20-2003, 05:42 PM Thread Starter
rwcloukey
do your 33's rub?
81 cj7.
I6
herced tub
diamond dash
post #4 of 4 Old 03-21-2003, 11:38 PM
rok_toy
rok_toy's Avatar
33's will rub.
33" tires will not stuff into the rear wheel well without rubbing, unless you cut some metal( or do a body lift). The wheel opening is smaller than 33". If you plan on getting full articulation, you will have to do some modifying( cutting the wells, or body lift). They will fit, with minor rubbing, if you don't mind that.
I've been there, done that.
1986 CJ-7, 258/T5/Dana300, Dana 44's, 4.89's, ARB's, SOA, Warn8K, high-steer, 37" MTR's, onboard air( york style)...more to come!!
rok_toy is offline
Help with lifting my 7 jksull Jeep CJ Forum 8 07-15-2008 04:35 PM
Lifting my CJ more jfrdog Jeep CJ Forum 10 07-16-2007 08:18 PM
Help w/ Lifting cj newbie Jeep CJ Forum 18 02-09-2007 08:13 AM
lifting a cj mike4089 Jeep CJ Forum 1 11-04-2005 07:48 PM
Lifting Smokey124421 Jeep CJ Forum 1 06-22-2004 02:01 PM
