Lifting my CJ? - JeepForum.com
post #1 of 4 Old 02-17-2002, 11:18 PM Thread Starter
Cophgnsnuf
Post Lifting my CJ?
Ok I am a newbie here on the forum but I have a question.. I have a 82 CJ7 that I am running 36" superswampers on.. I did the SOA on it but I did not put a 2.5 inch lift and now my front springs are starting to sag a bit Drivers side more than passenger side. What I wanted to know was since I am running short on cash at the moment to put the lift on it I want would it work the same if I put say add a leafs and longer shackles on it or do I have to get the suspension lift kit to fix this problem.. ? Also I am looking at dropping out my AMC 20 rear for a ford 9" but I have heard that there is some cutting to do on the 9" both on the axels and the housing unit can anyone tell me how hard this will be to do if I go with the 9"?
82 CJ7 36" superswampers. SOA ,2 1/2 inch lift springs and a whole lot of dreams. My baby.
Cophgnsnuf is offline
post #2 of 4 Old 02-19-2002, 02:53 PM
T Hoff
1975 CJ5
Post
I'm surprised you haven'y blown the crap out of that rear axle already.
Any Ford 9" you get will have to be modified. The tubes will have to be cut on each side of the Pumpkin to make it the same lengths as the original AMC20 and the spring perches have to be welded into the correct position. A Dana 44 is a strong axle and since they put those in the earlier Jeeps the Mods. might be less. There are plenty of Axle companies out there that can build you a 9" almost on a phone call. But be ready to lay out some bucks.
The suspension...I have two spring shops by me, and I have brought my Pickup truck in there and told them what ride I wanted and how high, and they did a sweet job for less then a kit. The shackles are a band-aid but it's a cheap temperary fix.
'75 CJ5 ---Chevy HP 350 motor-- All Fiberglas---one piece tilt forward nose
1985 chevy stepside pickup, 300K on the clock: Original Owner
1989 Volvo 240 300K on the clock: Original Owner
the 1991 X is my newbie with 331K on the clock: bought OCT.'03 with 183K
T Hoff is offline
post #3 of 4 Old 02-20-2002, 12:12 PM Thread Starter
Cophgnsnuf
Post
I have heard that from so many people that they are suprised I have not blown out my rear yet but I have been running this way for about 2 yrs and no problems with it yet but I have been looking into going stronger as my driving is getting a bit more aggressive as I seek harder challenges thanks for the info
post #4 of 4 Old 02-20-2002, 01:52 PM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
Cool
Copey:
If you're really short on cash, get your springs rearched at a reputible spring shop. Thay can also add an ince or so, but as you know the springs will sag back eventully.
Also, you could try to find some of the heavy-duty springs (from the factory with one extra leaf) from a salvage yard. Seems less than likey, but with so many guys buying lift kits, there may be some decent stock springs tucked away in some random places.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
Help with lifting my 7 jksull Jeep CJ Forum 8 07-15-2008 04:35 PM
Lifting my CJ more jfrdog Jeep CJ Forum 10 07-16-2007 08:18 PM
Help w/ Lifting cj newbie Jeep CJ Forum 18 02-09-2007 08:13 AM
lifting a cj mike4089 Jeep CJ Forum 1 11-04-2005 07:48 PM
Lifting Smokey124421 Jeep CJ Forum 1 06-22-2004 02:01 PM
