lifting engine by oil pan damage gasket? - JeepForum.com
post #1 of 5 Old 06-06-2014, 07:23 AM Thread Starter
nmjeep84
Anyone that lifted the engine by the pan to replace mm have damage to pan gasket or rear seal from the lift?
nmjeep84 is offline
post #2 of 5 Old 06-06-2014, 07:54 AM
duffer
1955 CJ3B
I have done that numerous times with GM small/big blocks, V6's and the Willys 134's for various repairs and have never had a problem. I would assume the AMC pans are also stout enough for this but have not done that with any of them.
1955 CJ 3B, 381cid sbc (441cid all aluminum sbc coming soon), AGE M22W, Teralows, Warn OD, OBA, Premier Power welder, Warn 8274
1968 CJ 5, factory 225" w/ headers/450 cfm Holley, T86AA, Belleview winch, Warn OD
2012 Wrangler Rubicon Unlimited, Warn 9.5 xp-s winch
duffer is offline
post #3 of 5 Old 06-06-2014, 08:26 AM Thread Starter
nmjeep84
thanks
nmjeep84 is offline
post #4 of 5 Old 06-06-2014, 08:30 AM
1949er
1949er is offline
post #5 of 5 Old 06-06-2014, 12:14 PM
LumpyGrits
Better to lift via the side-flange of the pan, than from the pan's bottom.
A 2x8 block of wood works well for this.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
