Lifter Help - JeepForum.com
post #1 of 4 Old 05-02-2010, 07:13 PM Thread Starter
elks96
Lifter Help
OK so I am into my motor pretty far. I have to swap out my cam as the oil pump gear keeps eating the distributor gear. I have the head all the way off and am now looking at the lifters. I see a little C snap thing holding the lifter down. Before I went digging around with a large screw drive I thought I would ask the best way to get at the lifters. Also how to get em out? Big Magnet?
As you can tell this is beyond my experience. So all good advice is great. I have to learn sometime.
1985 CJ 7 258 bored/Cammed, MotorCraft Carb, Mallory Ignition, NP435/Dana 300, 4.5 RE Ex, 1.25 JKS Body Lift, Detriot AMC 20 Rear(detroit locker and Warn Hub Conversion), Herculined Tub, Chevy Heater Blower, 34" Swampers, Custom Rear Bumper, more to come....
1972 K5 8" lift, 36" swampers, lockers, custom paint.
elks96 is offline
post #2 of 4 Old 05-02-2010, 08:44 PM
zombiesmasher13
If you have the motor out you can just spin the block upside down and they should come out but if not.....Get a magnet that telescopes. I would suggest a rare earth magnet, they're a lot stronger. A pair of long needle nose pliers comes in very handy as well. When you get your cam make sure you get the cam/lifter set and not just the cam. When you replace one you really need to replace the other. Good luck on it
zombiesmasher13 is offline
post #3 of 4 Old 05-03-2010, 06:32 AM
Oily
I thought our common problem was the distributor gears chewing up cam gears. Solved by changing out the gear on the distributor.
Oily is offline
post #4 of 4 Old 05-03-2010, 07:18 AM Thread Starter
elks96
Well for some reason I have went through 3 distributor gears in about 3000 miles. I just barely get everything set, then bam a tooth get skipped. I am pretty certain my cam shaft gear was damaged some how. I also just mis-posted about the issue.
Thanks a bunch.
elks96 is offline
Noisy lifter sparkey Jeep CJ Forum 1 03-26-2009 04:23 PM
Lifter tap 78treehugger Jeep CJ Forum 4 01-14-2009 08:51 AM
lifter smackout Jeep CJ Forum 2 07-11-2007 05:16 PM
Lifter question? BIGM Jeep CJ Forum 2 12-26-2006 06:12 PM
304 Hyd lifter replacement tet-ness-shot Jeep CJ Forum 4 08-23-2006 11:37 AM
