Lifted CJ7 Now Steering Shaft Too Short? - JeepForum.com
post #1 of 16 Old 05-13-2011, 02:56 PM Thread Starter
cpistorius
Hi all,
Seems after my body lift and front shackle replacement, has created sterring issues. Seem like the knuckles on the lower end of my steering shaft now dont reach into the lower coupling that turns the steering box. Do I need a longer shaft or is there another fix for this? Thanks!
cpistorius is offline
post #2 of 16 Old 05-13-2011, 03:25 PM
markso125
1982 CJ7
How big of a body lift did you go?
Yes you are going to have to get a new steering shaft, and possibly clutch rod, and extend your shifter for your transfer case and transmission.
If you run to high of a body lift the cost of the steering shafts and extending all of your brackets and things like your clutch rods can quickly negate the cost saved with going for a body lift over an suspension lift. So if you go too high of a body lift, like 3" or higher you might as well just buy a full suspension lift.
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
markso125 is offline
post #3 of 16 Old 05-13-2011, 03:36 PM Thread Starter
cpistorius
I only did a 1" body lift and about an 1" front shackles, but the shaft definitely does not fit squarely into the lower coupling now.
post #4 of 16 Old 05-13-2011, 03:58 PM
gojeepin
1983 CJ7
A one inch body lift shouldn't make your steering shaft too short and shackles have no influence on it at all.
Nevertheless, if your steering shaft is too short, has it been collapsed? The stock shaft is two-piece.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #5 of 16 Old 05-13-2011, 04:03 PM Thread Starter
cpistorius
no the steering shaft has not been collapsed I also just put in a new lower shaft assembly the bearing nuts, the boot the clip that stuff. it almost seems like if I could change the angle of the steering box that would do it
post #6 of 16 Old 05-13-2011, 07:17 PM
contdevelop
Take the body lift off. Body lifts suck.
contdevelop is offline
post #7 of 16 Old 05-14-2011, 06:12 AM
1911Tyler
1977 CJ5
My new shaft had a kind of glue in it where it slipped inside itself. So I heated with a torch slid out to the length I needed. Then put a little tach weld so it wouldn't slop around. But at the same time it would break and collapse in a wreck.
1911Tyler is offline
post #8 of 16 Old 05-14-2011, 06:55 AM
mopar408
1974 CJ5
CPI, read # 7. then read it again
That is your answer, body lift or no body lift.The shaft is adjustable, with some work. that 's what lets it collapse in a wreck.
If it's good TO you, it's gotta be good FOR you....
mopar408 is offline
post #9 of 16 Old 05-14-2011, 09:54 AM
1911Tyler
1977 CJ5
post #10 of 16 Old 05-14-2011, 09:58 AM Thread Starter
cpistorius
So you are saying that thestock shaft is adjustable? Looks like to me there are 2 small pins locking it in place.
post #11 of 16 Old 05-14-2011, 01:25 PM
mopar408
1974 CJ5
they are PLASTIC. Jeep made the shaft o.e, in the correct length and then used the molded plastic to hold it at that length with a little resistance but light enough to shear in a crash. Your lift altered the length that it now needs.
Take a torch w/ rosebud and heat both pieces and tap on it, working it loose til the plastic melts and burns away. It will then slide back and forth ( it's plenty long ) install and mark correct length. Drill one small hole thru it and install one 10/32 brass machine screw to hold at proper length but serve as a shear pin.
mopar408 is offline
post #12 of 16 Old 05-14-2011, 02:34 PM Thread Starter
cpistorius
Thanks mopar, appreciate it. When you say heat both pieces, you mean the plastic pins, right?
post #13 of 16 Old 05-14-2011, 03:11 PM
1911Tyler
1977 CJ5
Yes where it slides together I just heated mine with a little propane torch slide it till it fit. But if you just left it like that their would be a little bit of play in it. So small bolt or a little tach weld to hold it tight.
post #14 of 16 Old 05-14-2011, 06:38 PM Thread Starter
cpistorius
Cool, got it done! Thanks for the help.
post #15 of 16 Old 05-14-2011, 08:57 PM
markso125
1982 CJ7
hate to say it Mopar has nothing to do with it, you are still talking about AMC way back then..
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
steering box , steering shaft
is axle shaft to short to be used? Builder77sDad Jeep CJ Forum 3 07-15-2011 02:34 PM
Short Shaft Syndrome (Steering) nedmoore Jeep CJ Forum 10 12-30-2010 07:52 AM
YJ tub swap....steering shaft too short? scottymac62 Jeep CJ Forum 8 10-17-2009 10:16 PM
1" BL makes steering shaft too short? Matt in TN Jeep CJ Forum 9 04-10-2006 11:14 AM
Slight body lift-steering shaft too short hfjeff Jeep CJ Forum 4 04-30-2004 06:06 AM
