Lift Lip type materials?? - JeepForum.com
post #1 of 5 Old 09-24-2007, 06:50 AM Thread Starter
KSToyz
KSToyz's Avatar
1982 CJ7
My CJ has a 3" body lift and while I'm decently satisfied with the job the PO did installing it I'm not satisfied being able to see right through the underside of the jeep. Has anyone used a material to create a custom fit set of fillers similar to the lift lips concept except full length?
Or should I just live with the gap given that you can see alot of the trans/transfer case very easily?
Thoughts?
James
1982 CJ7 w/ YJ Tub, 258I-6 .030 over, Offenhauser Intake, Holley 390 Carb, Borla Header, D30 Front & AMC 20 Rear (One Piece Superior Axles), 4.88 gears, 2.5" Spring & 3" Body Lift, 35x12.5x 15's, Besrk Made Front/Rear/TC bumpers, Mastercraft Seats, Poison Spider Full Cage, LineX Interior
KSToyz is offline
post #2 of 5 Old 09-24-2007, 09:11 AM
jayhawkclint
jayhawkclint's Avatar
1970 CJ5
I noticed you've already got an extended inner fender in front. It really doesn't look too bad from this angle, IMHO. You may end up spending a lot of effort covering it up only to draw even more attention to it when other Jeepers get to peepin' under your rig, 'cause you know they will.
My '70 CJ5 Build Thread:
jayhawkclint is offline
post #3 of 5 Old 09-24-2007, 09:28 AM Thread Starter
KSToyz
KSToyz's Avatar
1982 CJ7
You may be right Clint. The front isn't horrible but there is obviously a good size gap under the body of the Jeep that is my main issue. Might just leave it as it does provide additional space for visual inspection.
James
KSToyz is offline
post #4 of 5 Old 09-24-2007, 12:02 PM
slacker92104
slacker92104's Avatar
Totally off topic, but where did you get your windscreen KSToyz?
'81 CJ5, efi 302, AX-15 5 spd, On Board Air, wrangler spring conversion, Astro van Hydro Brakes.
Soon: Custom cut Dana 44 front, wide trac solid axle amc 20 rear, SOA,
slacker92104 is offline
post #5 of 5 Old 09-24-2007, 12:12 PM Thread Starter
KSToyz
KSToyz's Avatar
1982 CJ7
Slacker,
It came with the Jeep when I purchased it so I'm not sure...sorry I couldn't help.
James
KSToyz is offline
original seat repair costs and materials, bolster and vinyl for 1974 incynr8 Jeep CJ Forum 1 07-07-2009 08:32 AM
holley type and dial type fuel press regulators ktm25089 Jeep CJ Forum 4 07-18-2008 04:47 PM
How can I tell what type / height of a suspension lift (leaf spring) tlhigh Jeep CJ Forum 2 04-03-2008 10:01 AM
OIl type in my CJ7 mmerlina Jeep CJ Forum 10 11-07-2007 06:54 PM
how to tell what type of lift? certifiablejeep Jeep CJ Forum 15 10-10-2002 05:45 AM
