Lift kits? - JeepForum.com
post #1 of 3 Old 09-26-2011, 09:18 AM Thread Starter
Gido
1980 CJ7
Lift kits?
Hey y'all, I am wanting to put 35" tires on my stock 1980 cj7. What height lift kit do I need to get and what would be a good brand name? Thanks
"At first you don't succeed, get a bigger Hammer!"
in memory of Jimmy Smith - a wise man
Gido is offline
post #2 of 3 Old 09-26-2011, 09:24 AM
monsonman
monsonman's Avatar
depends on how much cutting you are willing/not willing to do but generally you would need 4"+ to run 35's, but expect some rubbing. I've got 36's with 4" lift springs and long shackles.
This is assuming you want to stay spring under. with spring over you can use your stock springs and you will be able to clear 35's
'05 LJ Rubicon Build:
'98 TJ- build:
instagram: @vohnsonthemonson
monsonman is offline
post #3 of 3 Old 09-26-2011, 09:28 AM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
look into spring over, its what i plan on doing and all ive read is that if done right it is better than any other lift. and you can use stock yj springs. search the forums as their is TONS of info on SOA on here
if you dont want to go that route then check out the rubicon express 4.5"
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
