Lifetime Supply of Relays $50 - Page 2 - JeepForum.com
post #16 of 19 Old 02-08-2010, 11:23 AM Thread Starter
Exposed
Exposed's Avatar
1981 CJ5
These are just the relays, not the holder. You can buy different types, weather proof, no weatherproof or just the 1/4" spade female connectors to attach. The weatherproof holders like the guys are talking about from the salvage yard, are very expensive new. If you need weatherproof ones new, I found Omron (probably who makes the GM ones) for about $11 each. That is why the salvage yards are the best place to find. Since I built a box to keep weather out, I bought the mounting bases (Waytekwire.com) for $0.60 and spade connectors and made my own.
Exposed is offline
post #17 of 19 Old 02-08-2010, 11:50 AM
trailhead2004
1980 CJ7
Originally Posted by ElZorro View Post
Are these relays weatherproof like the GM ones?
Check my post a few back in this thread. I gave all of the info for buying the Omron skirted relays and a pretty economical sealed base. As Exposed mentioned, the relays and bases can be pretty expensive if you don't know where to look and buy. With the parts I listed, you can do one relay, minus the wire, for about $11.00 including a sealed connector/base.
These parts do work as I have been testing them on my dual sport motorcycle for about 2 years. I had to convert my motorcycle from a split AC/DC system to a full DC system and needed a relay to isolate stuff. Properly assembled, this setup is very robust. Very capable for use in the engine compartment. I am going to use these non-sealed units for a few applications inside the cab where it is theoretically dryer.
trailhead
"Bad things happen to you because you're a dumba$$"
Red Foreman
trailhead2004 is offline
post #18 of 19 Old 02-08-2010, 12:02 PM
JeepnBlake
Mine are from a 92 or 93 Deville, really easy to spot, right on the firewall in this case, i even took the bar they were mounted on, all for around $5.
Around here salvage yards are a rip off circus.
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is online now
post #19 of 19 Old 02-08-2010, 01:57 PM
86cj74.2L
86cj74.2L's Avatar
The relay for the manifold heater is different from the other relays.
It has a different make and break voltage because it uses a resistor to pull in the relay for the heater.
Other then that good deal.................
86cj74.2L is offline
Power supply to sending unit? jeepwhore Jeep CJ Forum 7 05-29-2007 07:31 AM
Air Supply--not just a band in a jeep Collard Green Jeep CJ Forum 7 05-24-2007 02:05 PM
Using Por 15/Supply elks96 Jeep CJ Forum 8 05-18-2007 09:31 AM
brake supply question gumby Jeep CJ Forum 6 12-22-2006 06:51 PM
How big of a fuel supply line for a 360 HIPPER Jeep CJ Forum 3 04-11-2004 08:57 PM
