Let's talk about cable shifters - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Let's talk about cable shifters
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 07-02-2011, 09:52 AM   #1
BioTex
My TF727/NP208 needs a shifter. I have several mechanical shifters, but it looks like to make them work, I will need to fabricate a bunch of brackets.
I'm thinking maybe a cable shifter is the way around that. Problem is, I have absolutely no experience with cable shifters.
I'd like to hear your opinions on them. What to look for etc...
'85 CJ7, BDS 4" lift, 1" Body lift, 33x12.5, Shrockworks Sliders, 304 V8 with RV cam., T-176, D300, Dana 30, AMC 20.
1986 CJ10-A SD-33 Diesel/727/np208
1971 800B with 345/T-19
06' TJ Rubicon, 4" R.C. springs, BFG/AT 35s M.C. 6" fenders, rockers and surrounds, Currie front & rear adj. tracbars, tattons DC rear shaft, adj. upper - lower CA's. Bilstein 5100's
YJ Buggy Build Current project. Stroker/FI ?
1990 MJ Comanche 4.0L AX15/np231
BioTex is offline   Reply With Quote Quick reply to this message
Unread 07-02-2011, 09:54 AM   #2
ctrim78
I went with the B&M Megashifter on mine. Really simple, sits nice and high, is fully adjustable, and works awesome! Even comes with lighted gear indicator, neutral safety and reverse lockout built in. Can't beat it!
ctrim78 is offline   Reply With Quote Quick reply to this message
Unread 07-02-2011, 10:08 AM   #3
BioTex
I need to more clear. Sorry. I'm talking about a cable shifter for the tranfer case. I have a column shift for the auto.
Unread 07-02-2011, 10:16 AM   #4
Lordwrench
1978 CJ7
Check these out, very stout looking units.I haven't used them,yet.
http://www.northwestfab.com/Shifters.html
Lordwrench is offline   Reply With Quote Quick reply to this message
Unread 07-02-2011, 10:23 AM   #5
jeepdaddy2000
1971 CJ5
They tried transfercase cable shifters early on and found that due to infrequent use, they had a bad habit of corroding and freezing up.
jeepdaddy2000 is offline   Reply With Quote Quick reply to this message
Unread 07-02-2011, 10:29 AM   #6
BioTex
Nice link. I don't see one listed for an NP208, but I will contact them and see what they say. Thanks...
Unread 07-02-2011, 10:30 AM   #7
BioTex
Good point! Since I live in the desert, corrosion won't be a problem for me. Maybe for the next guy though
Unread 07-02-2011, 10:31 AM   #8
Lordwrench
1978 CJ7
They look like they could make just about anything,keep us posted on what you find out with them.I have admired their products for some time.
Luckily for us,technology has come a long way since early on days....
Unread 07-02-2011, 10:39 AM   #9
BioTex
So true! I just e-mailed them.
The NP208 is just a simple lever operation. If the lever were closer to the tunnel, I could just extend it. But being a good foot below the floor pan, the travel would be too much. I have a floor shifter from a qudratac that would work with a bunch of brackets, but...
What about a thicker tranny tunnel? If I made a strong enough cover, I could use it to spread the load. Hmmmmm!
Unread 06-30-2013, 05:28 PM   #10
Kastraelie
1977 CJ7
Hey BioTex...did you ever figure this out? What route did you go? I'm at this point in my project.
Building out a Jeep is like trying to smother a fire with twenty-dollar bills. You just never have enough at once to put it out...
My Frame-Off
Kastraelie is offline   Reply With Quote Quick reply to this message
Unread 06-30-2013, 05:59 PM   #11
gmakra
I have a Northwest cable shifter and its a good ubit.
gmakra is offline   Reply With Quote Quick reply to this message
