Lets see your Warn 8274 on your cj! - Page 7 - JeepForum.com
post #91 of 127 Old 03-16-2013, 06:44 PM
SKT
This one isn't mine.
Original paint CJ-7 with an 8274.
SKT is online now
post #92 of 127 Old 03-16-2013, 07:16 PM
Heyjack
1977 CJ5
1981 cj5
Heyjack is offline
post #93 of 127 Old 03-16-2013, 08:07 PM
SKT
Originally Posted by Heyjack
1981 cj5
That's a great looking original paint CJ-5!
SKT is online now
post #94 of 127 Old 03-16-2013, 08:49 PM
Heyjack
1977 CJ5
Thanks
Heyjack is offline
post #95 of 127 Old 03-17-2013, 01:53 AM
DYontheForum
1981 CJ7
They seem awful big. Do they effect the engine cooling system?
DYontheForum is offline
post #96 of 127 Old 03-17-2013, 07:17 AM
Archie B
Junior Member
Archie B's Avatar
1977 CJ5
Let's see your Warn 8274 on your cj!
I've had mine on for about 25 years and it has never gotten hot due to the 8274.
Archie B is online now
post #97 of 127 Old 03-17-2013, 09:17 AM
82JeepCJ7
1982 CJ7
I have never had an issue with cooling due to the winch. They are not all that "big" just configured differently than the cheap winches. They are bigger because they have actual gears that run in gear oil inside. No planetary gears to fail. There is a reason the design has been around since 1974, and the predecessor (basically an older version lacking the automatic brake) the Belleview winch was made from 1959-1973. The old adage of "if it works, don't fix it" holds true.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #98 of 127 Old 03-18-2013, 09:50 PM
poppatello
I haven't installed my yet either. I still need to rebuild it. But you guys aren't worried about someone stealing them? Everyone is just using regular bolts. I've heard many stories around here of winches getting taking off the front bumpers. I plan to use something like this when I install mine.
http://ors4x4.com/Factor-55-Winch-Lock/
In a world full of copy cats, be an original...
Paved Roads
A Fine Example of Needless Government Spending
Originally Posted by berserker View Post
Sometimes it a good idea to pull a vacuum hose before the wife rides in it--you can tell her you need a new ____ and once you get your new ____ you can reconnect the hose. :)
84 Cj 7 w/ 4-Banger, 4.5" BDS lift, 1/2 Trans Drop, Twin Stick, 32" Tire, Front Aussie Locker, No Sound System Yet, No Armor, Warn 8274 Not Installed, Webber Carb Upgrade, Luckycheese Ing. Upgrade...
poppatello is offline
post #99 of 127 Old 03-18-2013, 10:02 PM
82JeepCJ7
1982 CJ7
After the top bolts are tight, weld a piece of steel up against one flat. Those bolts are not coming out with out a grinder to cut the piece of steel off. Never weld on a bolt head.
I've also seen people people weld a short piece of tube over the head of the bolt. Warn Hawse fair leads come with expanding plugs that cover the lower bolts.
post #100 of 127 Old 03-19-2013, 06:58 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
My Warn mounting bracket has two bolts that require finagling a 3/4" wrench onto the nuts on the underside of the bumper, which is a very difficult maneuver while laying on your back. I don't see a thief taking the time to do that.
Matt
Matt1981CJ7 is offline
post #101 of 127 Old 03-19-2013, 06:59 AM
walkerhoundvm
1981 CJ8
I haven't installed my yet either. I still need to rebuild it. But you guys aren't worried about someone stealing them? ]
have you tried carrying these things around?!?! I feel sorry for the SOB who tries to steal my 8274.
walkerhoundvm is offline
post #102 of 127 Old 03-19-2013, 07:46 AM
Kirk1
1983 CJ7
I am told mine was ordered from the factory and shipped as a loose part then installed by the dealer.
Kirk1 is offline
post #103 of 127 Old 03-19-2013, 09:50 AM
82JeepCJ7
1982 CJ7
Yup, the 8274 was a dealer installed option. An option EVERY Jeep should come standard with.
post #104 of 127 Old 03-28-2013, 10:37 AM
geoiel
1978 CJ7
8274 Winch
geoiel is offline
post #105 of 127 Old 04-24-2013, 01:04 PM
GrantYJ
Technically, it's a YJ, but hey ...It's got most of a CJ front clip? Apparently, UPS just delivered my Synthetic winch rope, so It'll have rope and a hook by the end of the evening....
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline
