Lets see your Warn 8274 on your cj! - Page 2 - JeepForum.com
post #16 of 127 Old 02-29-2012, 03:59 PM Thread Starter
ol78cj
1978 CJ5
Sweet set ups you guys have! Look great nothing like a ol 8274 on the front of a jeep now I gotta search for me one before I have a fit! Haha!
ol78cj is offline
post #17 of 127 Old 02-29-2012, 05:07 PM
LargeAl
Dirt Gobbler
LargeAl's Avatar
1979 CJ7
on my old seventy niner...
God Bless Our Troops...
LargeAl is offline
post #18 of 127 Old 02-29-2012, 05:16 PM
dmock
1984 CJ8
My 84 CJ-8
dmock is offline
post #19 of 127 Old 03-02-2012, 10:00 AM
red mistress
1983 CJ8
8274
8274 is my favorite winch ever built, no CJ is complete without.
My modified Scrambler, in process of installing Jeep SE 8274 with OEM brushguard on orginal
And my CJ-7 with "Jeep Special Equipment Warn 8274" and Jeep serial number stamped 8274.
67 Gladiator 15K AMC327 PTO Ramsey D44, D60 69 Jeepster deluxe Convertible Power 82 CJ-8 75K Renegade all original 83 CJ-8 50K 401 MPFI ARB60's front & rear winch 38" 84 CJ-7 38K Garnet interior, Jeep SE 8274, 8" x 33" 87 J20 36K Jeep SE Hidden winch, boat rack, 35" 2006 LJ Rubicon 3K
red mistress is offline
post #20 of 127 Old 03-02-2012, 10:30 AM
von_schmirrinof
1979 CJ7
Mine when I got it......currently removed for rebuild
von_schmirrinof is offline
post #21 of 127 Old 03-02-2012, 12:41 PM
bentring
1976 CJ5
I had no idea when I got the Jeep if the winch was a good model or not but I knew being a Warn I could rebuild it when I got around to it. It worked great pulling itself onto a trailer but I will NOT use it under load in the current condition. The PO said he wanted to be near the winch so he could see what was going on when he used it.
bentring is offline
post #22 of 127 Old 03-02-2012, 01:18 PM
kconnor123
1978 CJ7
There is a toggle switch on that winch! Wow, that was a PO with a deathwish! Or at least wanting a winch hook to the skull.
1978 CJ7 I6, 2.5" dik cepek spring lift, 0.5" shackle lift, Cooper Discoverer S/T 33's, 1.25" Wheel Spacers.
Whats Next: Wide track swap, winch, new seats, eventually a 4.0 mpi swap from a 90's cherokee or wrangler.
kconnor123 is offline
post #23 of 127 Old 03-02-2012, 02:14 PM
13riverking
1981 CJ7
here's mine
13riverking is offline
post #24 of 127 Old 03-02-2012, 02:35 PM
duffer
1955 CJ3B
This is a 5721 but it is in the process of being replaced by an 8274 (requires moving the right side mount in a couple of inches). Everyone will have their own opinions, but I have a real problem with 200 lb winch bumpers and I also like to mount the winch low so the lower fairlead roller will allow the cable to be strung back under the Jeep. You get less radiator obstruction and a lower center of gravity mounting low. The fairlead only uses the Warn rollers, the rest was fabed with the bumper.
Those rollers will be replaced with these for the use of rope on the 8274.
duffer is offline
post #25 of 127 Old 03-02-2012, 03:30 PM
walkerhoundvm
1981 CJ8
I like that idea, I'm considering having a bumper built locally for my 8274 and wondered what the opinions are against it?
walkerhoundvm is offline
post #26 of 127 Old 03-02-2012, 03:55 PM
bentring
1976 CJ5
I blame it on ignorance.
I've seen what happens when a cable breaks under stress, which is why I was wary while using it just to get it on the trailer, and would never consider using as-is if it was stuck...
bentring is offline
post #27 of 127 Old 03-02-2012, 06:51 PM
82JeepCJ7
1982 CJ7
Move the switch in the cab.
Duffer, I like the hydraulic disc brake.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #28 of 127 Old 03-02-2012, 07:21 PM
BlueRubiconrich
the last of the CJ's (86)with a Warn 8274
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #29 of 127 Old 03-08-2012, 12:58 PM
Erik719
1983 CJ7
Here's mine.
'80 CJ7 - Gone but not forgotten
'83 CJ7 - Donkey
Erik719 is offline
post #30 of 127 Old 03-08-2012, 05:48 PM
OKRenegade
I will eventually be getting a Bersk bumper, the one on there now is leftover from the PO. He said he hadn't run the winch in years. All I had to do was add new wiring to the battery and to the solenoids, wack the solenoids with a hammer and it started right up.
OKRenegade is offline
