Lets See Those Extra Lights n Mounts... - JeepForum.com
post #1 of 4 Old 01-03-2010, 01:28 PM Thread Starter
poppatello
I need more lights. I have a surf rack I put on for the season which will be coming up soon and when it's on the jeep my head lights are blocked. Also, when I go mudding the lights get covered so I want to install some extra lights. I would like to see what you guys have done and how you like them. I also would like to know who you guys ran the wires from the lights to the inside switches.
In a world full of copy cats, be an original...
Paved Roads
A Fine Example of Needless Government Spending
Originally Posted by berserker View Post
Sometimes it a good idea to pull a vacuum hose before the wife rides in it--you can tell her you need a new ____ and once you get your new ____ you can reconnect the hose. :)
84 Cj 7 w/ 4-Banger, 4.5" BDS lift, 1/2 Trans Drop, Twin Stick, 32" Tire, Front Aussie Locker, No Sound System Yet, No Armor, Warn 8274 Not Installed, Webber Carb Upgrade, Luckycheese Ing. Upgrade...
poppatello is offline
post #2 of 4 Old 01-03-2010, 02:23 PM
JavaTee
1979 CJ5
Since I didn't send any pics of the mounts in the pm, here you go
(The mounts aren't pretty, but they work, and they cost me 45 minutes of time. )
The wiring is run under the windshield weather strip, and then down to the relay wires.
Later, T.J.
'79 CJ5 258 w/MC 2100 & Team Rushed, NP435/Dana300 <--twin sticked, NT Dana 44 (w/Aussie) rear, and NT Dana 44. 3" susp lift, Currie shackles, 1" body Lift, Durabaked tub inside & out.
Military members (current or completed service) check out
JavaTee is offline
post #3 of 4 Old 01-03-2010, 03:24 PM
Mike Romain
For power, I like to use a relay with just a trigger ground wire going to the switch. that way only an 18 ga. wire that is a ground needs to run into the tub for the switch.
See: The Bosch Relay Unraveled for wiring schematics.
I also use dedicated grounds for each light. The stock Jeep ground straps are only rated for the stock Jeep things, adding lights or a big stereo need added grounds.
Mike
Mike Romain is offline
post #4 of 4 Old 01-03-2010, 04:04 PM
John Strenk
John Strenk's Avatar
1976 CJ5
I like these a lot. They throw off a tremendous amount of light that I need at night. No back spill or anything to reflect off the front, except maybe snow.
John Strenk is offline
CJ lights, no headlights, rear running lights and front parking lights on constant Blthomas Jeep CJ Forum 25 02-17-2009 12:28 PM
lets talk H.D steering box mounts.. Mr.Crowley Jeep CJ Forum 24 06-19-2007 01:58 PM
if i had some extra ca$h Magic2979 Jeep CJ Forum 5 09-01-2006 10:11 AM
Shock Mounts and Rad mounts 79 CJ7 Jeep CJ Forum 2 07-03-2006 04:14 PM
Do I need that extra gas?! Jwhit Jeep CJ Forum 2 11-17-2004 08:40 PM
