Let the games begin - new build 86 CJ7 - JeepForum.com
post #1 of 730 Old 06-07-2010, 04:40 PM Thread Starter
Eaglekeeper
Brought home a month ago and started the teardown a few weeks later. As you'll notice, this is only my second post. For the last few months, I've been trolling and learning tons of great info and gathering ideas from all the posts on this site. At first, I planned to bring this old CJ back to stock life, but now :
Only one pic for now, just to make sure posts go ok. More will follow. At this point, it's tore down all the way and the inspection is complete.Body has some rot in a few places. Motor is at the machine shop, Tranny is in good shape, just needs minor seal work. Transfer case needs a master rebuild kit. Rear axle not too bad and needs seals and one piece axles. Front axle will require major rebuild. I'll order the parts in a month or two, and for now, I'm working on the frame. Plan is to get it back to a rolling chassis and begin on the body.
Looking forward to the forums help in this build.
86 CJ7, 258 Engine, T-177, Dana 300.
A ton more pics here.
Eaglekeeper is offline
post #2 of 730 Old 06-07-2010, 11:27 PM
RoscoeJ
Congrats ,sounds like you have a plan! I got my 86 cj7 on the road a few years ago. Its good your putting some money into the engine! I also removed engine ,and went over everything ,replaced most everything that was rubber, there known for rear main seal leak, mine was shot. Timing chain was done too, but PepB had the complete timing chain kit for $13 bucks ! I had to remove water pump ,to install timing chain ,got a price on that it was like $24, and so on ..It all started with a leaking oil pan gasket,I can fill you in on what I learned if you have any questions PM me ! Post some pics ,and Enjoy the build!
RoscoeJ is offline
post #3 of 730 Old 06-08-2010, 04:04 AM
LightWalker
That's one thing I have noticed about these CJ's. Parts are pretty dang cheap!
LightWalker is offline
post #4 of 730 Old 06-08-2010, 08:20 AM
KMD
1976 CJ7
Yeah they nickle and dime you broke.
Best of luck with the build can't wait to see some pics and some progress.
KMD is offline
post #5 of 730 Old 06-08-2010, 08:27 AM
LightWalker
You are probably right. Nearly everything on my Jeep works, but that doesn't mean that my "to do" list is short. With CJ's, buying the vehicle may be the least expensive part!
Good luck to the OP, it sounds like he knows what he is doing.
post #6 of 730 Old 06-08-2010, 09:12 AM
JoonHoss
2011 JK Wrangler
Pic's, or it never happened
congrats, and welcome to JF
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #7 of 730 Old 06-08-2010, 09:57 AM
2Xtreme
2Xtreme's Avatar
1979 CJ7
It's all fun and games until someone breaks the bank!!
j/k
Congrats
2Xtreme is offline
post #8 of 730 Old 06-08-2010, 01:44 PM
TRex
1979 CJ7
Pics, pics, pics!
Also, here's a suggestion for your build-- find yourself an old priest and a young priest...
1979 Jeep CJ7
Follow My Build Thread: http://www.jeepforum.com/forum/f8/1979-cj7-build-project-trex-935022/
TRex is offline
post #9 of 730 Old 06-08-2010, 03:19 PM Thread Starter
Eaglekeeper
Pics (hopefully
Sorry for the delay. First pic was too big, I think, so maybe these will come through.
The Dana 300 and 30 (last two pics) was seriously gooo'd up but cleaned up OK.
If these pics post, I have a few questions to post a little later.
post #10 of 730 Old 06-08-2010, 03:34 PM Thread Starter
Eaglekeeper
Success with the pics. Now for some experts help.
I'm working on the frame and except for the crossmember I removed, a little rust on the rear body supports and some bad nutserts, everything is in good shape except for a spring hanger. The inboard side of the hanger tweaked the frame. Measurements are all good and appears the only damage is small bend and a bent hanger on the inside. In the pic, you can see the bulge and is only on the side. The bottom of the frame is still in line.
What's the best way to repair and reattach hanger? I've seen various examples from cutting a fitted patch to adding doublers. Since I live in Florida, I don't expect to do any rockcrawling, just some sandy fun and daily driving.
My welding skills are weak so this will be a learning event for me (but fun).
post #11 of 730 Old 06-09-2010, 08:21 AM Thread Starter
Eaglekeeper
Bump
Bump - Pictures and questions
post #12 of 730 Old 06-09-2010, 08:23 AM
JoonHoss
2011 JK Wrangler
FYI- bumping your thread is
Hoss
JoonHoss is offline
post #13 of 730 Old 06-10-2010, 06:14 AM Thread Starter
Eaglekeeper
Sorry about the bump. Still learning the site protocols.
post #14 of 730 Old 06-10-2010, 06:49 AM
DT5150
1983 CJ7
you a boom operator, or an f15 crew chief?
SOLD! 83 CJ-7. TBI Small Block Chevy 350/TH350/D300, Scout II Dana 44 front, CJ Dana 44 rear. 4" BDS Lift with 35's. Currently Jeepless.
DT5150 is offline
post #15 of 730 Old 06-10-2010, 07:15 AM
CJ Chet
You can probably use this:
http://www.civilianjeep.info/84-86FSM/CJ-FSM-84to86.pdf
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
81 CJ5 build ( Let the fun begin) JoeUSMC Jeep CJ Forum 42 02-25-2011 11:07 AM
Ahh, I begin looking at the '63 Cj-3b build... Lifesgoodhere Jeep CJ Forum 29 02-25-2009 02:36 PM
Brought home a YJ tub today for the CJ. Let the games begin...! Aaroneous Jeep CJ Forum 4 02-01-2009 08:51 AM
Let the painting begin nichols077 Jeep CJ Forum 22 04-26-2008 08:02 PM
The mods are set to begin gt4660 Jeep CJ Forum 8 02-09-2007 03:09 PM
