LED tail lights on a cj - JeepForum.com
post #1 of 15 Old 03-23-2010, 09:07 PM Thread Starter
mxracer919
1979 CJ7
Working on getting some led flushmounts in the cj, and I was looking but couldnt find any write ups on someone putting them in a cj. I am needing a 4.5" hole and am worried on the passenger side it will be close because of the gas filler and the top of the fender. going to be close, just wondering if any of you guys had any experience with this. Thanks!
mxracer919 is offline
post #2 of 15 Old 03-23-2010, 09:15 PM
locked-up-XJ
I just finished mine up. It wasnt to hard, i didnt take any progress pics but just make sure when your laying them out your not to high because you will run into some problems. Heres a pic if it helps.
And no matter how many times you check your measurements they always look off.
1999 TJ Custom 3 Link, 2.5" FOA Coilovers, 4.88 gears, Trussed D30, Locrite lockers, 35" MTR's
85' CJ7 Project "Bentsome"
In Progress
locked-up-XJ is offline
post #3 of 15 Old 03-23-2010, 09:41 PM
yellow85cj
If yours is a street Jeep, don't forget to have a plan for reverse lights and side markers. Might ask a local inspection shop if they are necessary for inspection.
Currently in pieces - all of them
yellow85cj is offline
post #4 of 15 Old 03-24-2010, 06:55 AM
rixcj
rixcj's Avatar
1979 CJ5
When I installed LED's, I moved the fuel filler from the rear of the tub to the side of the tub. This allowed me to install LED backup lights, as well.
You can see where I cut the fuel filler hose, sleeved the hoses at the cut, and swiveled the hose from the rear to the side location.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #5 of 15 Old 03-24-2010, 08:24 AM
Gunga
1978 CJ7
Check to see if you need a license plate light in your state too.
'78 CJ-7, 401 w/ headers, T-18, 35" muds, 4" lift, MSD ignition box, locked diffs.
Gunga is offline
post #6 of 15 Old 03-24-2010, 09:09 AM
jeeperman19
1984 CJ8
Also for a cj you need stat 262 flashers for both your hazard circuit and blinker circuit, so they don't blink too fast. The system has no resistance w/ led's, it does with the bulb causing the fast flash.
I'd recommend adding led parking lights up front as well. Does anyone know of led bulbs for the markers in tj flares?
http://i95.photobucket.com/albums/l131/jeeperman19/carcrush-1.jpg
http://i95.photobucket.com/albums/l131/jeeperman19/rubiconmemorial.jpg
jeeperman19 is offline
post #7 of 15 Old 03-24-2010, 10:19 AM
locked-up-XJ
rixCJ where did you get those crusher corners? not trying to hyjack or anything
In Progress
post #8 of 15 Old 03-24-2010, 11:05 AM
rixcj
rixcj's Avatar
1979 CJ5
I made them, along with the recessed fuel filler bezel, when I installed the lights. One thing led to another....
Rich
rixcj is offline
post #9 of 15 Old 03-24-2010, 11:11 AM
longboy
2006 WK
LEDs on the armor and reverse lights in the replacement rear crossmember:
2006 5.7l WK
longboy is offline
post #10 of 15 Old 03-24-2010, 05:18 PM
Jeepit85
I used a Volvo tractor light for my reverse light after installing my flushmount LED's. Works great on the trail at night. Probably throws more light than my headlites.
85 CJ7, Howell TBI, Twin Stick, 4:10's, 35" Pitbull Rockers, Clifford 6=8, Detroits, Matkins Level II, BDS 4", Summers Brothers. Skynyrd rocks.
06 Rubicon
06 Lance Camper
02 Dodge Cummins
06 VW Jetta TDI
Jeepit85 is offline
post #11 of 15 Old 03-24-2010, 05:34 PM
SparkyB
1988 FSJ Wagoneer
Really? I've done the led taillights on mine without changing the flasher and seen them on two others also on the stock flasher unit. Maybe it's just on the older CJ's?
79 CJ5
88 Grand Wagoneer
SparkyB is offline
post #12 of 15 Old 03-24-2010, 08:26 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Same with me, no problems with my leds.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #13 of 15 Old 03-24-2010, 11:05 PM
locked-up-XJ
If you still have your front marker lights then you will be fine. They have enough draw to activate the flasher. Its when you do all LED's you have a problem.
In Progress
post #14 of 15 Old 03-25-2010, 03:55 AM
Exposed
Exposed's Avatar
1981 CJ5
If you run all LED's or mix them with your original lights, just use an electronic flasher. They are not draw sensive and work with all. Plus, better than factory type flasher... Here is what I used on mine... They work fine on emergency and turn signal...
2 PIN ELECTRONIC FLASHER HEAVY DUTY Electronic Flashers Flashers Lights And Accessories* - Waytek Wire
Exposed is offline
post #15 of 15 Old 03-29-2010, 07:27 PM Thread Starter
mxracer919
1979 CJ7
Tail Lights 76CJ5ineburg Jeep CJ Forum 11 03-19-2009 10:20 PM
Tail lights jcooley7 Jeep CJ Forum 2 01-30-2009 11:15 AM
trailer lights for tail lights. anyone have pics? blackblazer92 Jeep CJ Forum 6 03-30-2008 08:41 PM
Tail lights...HELP! biglemon Jeep CJ Forum 5 07-28-2007 05:30 PM
Tail lights MudMonster Jeep CJ Forum 3 06-24-2003 08:25 PM
