Led parking lughts - JeepForum.com
 2Likes
post #1 of 22 Old 09-16-2012, 02:14 PM Thread Starter
vortec85cj
Led parking lughts
So I got my led parking lights installed, along with some HID headlights. Blinkers still don't work but at least the running lights do
vortec85cj is offline
post #2 of 22 Old 09-16-2012, 02:23 PM
Splinter
1980 CJ5
I'm having issues as well. I replaced the marker lights with LED, installed 10.5 ohm power resistors in parallel with them. No go. I have now picked up 6 ohm power resistors to see if that will work. The flashers were changed as well. If you find a solution, please post.
Splinter is offline
post #3 of 22 Old 09-16-2012, 02:43 PM Thread Starter
vortec85cj
Definitely. I've done the same things.my hazards work fine, do yours ?
post #4 of 22 Old 09-16-2012, 08:07 PM
har99
1979 CJ7
I have led front and rears, also switched out markers with led's, and added LED flasher and mine work. So my question is are there any regular bulbs in your system? If so try unpluging them and then see if you get the signals to work.
har99 is offline
post #5 of 22 Old 09-16-2012, 08:11 PM Thread Starter
vortec85cj
All my bulbs are led except for dash lights
post #6 of 22 Old 09-16-2012, 08:20 PM
Matt80cj
1980 CJ7
what did you use for the lights. I would like to do LED (headlights and marker- front and rear) but don't know where to start looking for parts.
Matt80cj is offline
post #7 of 22 Old 09-16-2012, 08:36 PM
aggiejon
1979 CJ7
Superbrightleds.com. Order a pair of amber stop/turn/tail (s/t/t) and install them behind the stock lenses. I used 2" screws and a piece of metal strap to hold them in place. I've heard of people opening up the holes on the grill and using the supplied grommets to mount. Then wire them up with a good ground. I wired my park on the tail function and blinker on the stop function. I do not believe that there is a single standard bulb on my jeep, indicator or dash.
The above site sells the appropriate bulbs to replace every light in your dash as well. Just remember, if colored light, match the color - blue (hi beam indicator), red(warning lamps), green (turn signal indicators), etc.
aggiejon is offline
post #8 of 22 Old 09-16-2012, 09:04 PM
Matt80cj
1980 CJ7
thanks that will help a bunch!! I'll look into that.
Matt80cj is offline
post #9 of 22 Old 09-17-2012, 04:37 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Cant use stock flasher with all LED Turn signals. You need to get an electronic flasher. Then you don't even need the resistors.
John Strenk is offline
post #10 of 22 Old 09-17-2012, 08:35 AM
bentshackle
1983 CJ7
Pretty sure you wired the resistors wrong. They should be in series. But I digress... Get an electronic flasher and scrap the resistors and you will be fine.
bentshackle is offline
post #11 of 22 Old 09-17-2012, 09:59 AM
John Strenk
1976 CJ5
Resistors should be in parallel to increase the load (Current) through the OEM flasher.
You (bentschackle) are probably thinking of the series resister used to limit the current to the LED which sometimes is also correct but it does nothing to help the flasher cycle. I'm pretty sure these LED replacement lamps already have current limiting resistors installed.
The 10.5 ohm and 6 ohms resistors will up the current from negligible to 1.2 to 2 amps through each side that might start the flasher to cycle.
The 6 ohm will be around 24 watts. Should put that in your defroster vents...
post #12 of 22 Old 09-21-2012, 05:46 PM
bentshackle
1983 CJ7
Touche salesman. I stand corrected.
post #13 of 22 Old 01-26-2013, 01:39 PM
Peck
I know this is a old thread, but does anyone have a suggestion for the electronic flasher relay or a part number off a relay that works. I am not wiring guru, but the relay I use now is a 2 wire flasher relay. How would I go about wiring a electric unit? Trying to swap over to KC amber LED front turns.
Peck is offline
post #14 of 22 Old 01-28-2013, 02:43 AM
John Strenk
1976 CJ5
I got mine at Walmart.
post #15 of 22 Old 01-29-2013, 07:03 AM
Peck
Is that LED friendly? My stock flasher worked with just the LED tail lights, bot not with front LEDs thrown is the mix.
Peck is offline
